Old 03-08-2008, 10:04 PM   #461 (permalink)
Points: 10,309, Level: 1 Points: 10,309, Level: 1 Points: 10,309, Level: 1
Simans82's Avatar
Car: 2007 Chrysler 300C SRT8
Member Number: 3988
Originally Posted by Blowndakrt View Post
That definitely sounds like a check valve issue. I am assuming you checked to make sure it wasn't leaking at crimps on the braided line or fittings going into the compressor and the tank.
I know you are just using them for back up, but you might want to get an external check valve. That will keep it from leaking at the tank back down into the compressor.
Shawn
Yeah, I sprayed this bad boy down with soap/water and see/hear no leaks whatsoever. It's going back through the hose though because when I take the intake off the pump, I can hear air coming back out of it.
Can you guide me in the right direction for an external check valve? Brands, places to buy, etc.?
Thanks Shawn!
Simans82 is offline
Old 03-08-2008, 10:23 PM   #462 (permalink)
Blowndakrt's Avatar
Member Number: 1851
Thanks Shawn!
Email me at Blowndakrt@mchsi.com
Shawn
Blowndakrt is offline
Old 08-27-2009, 09:28 AM   #463 (permalink)
Simans82's Avatar
Member Number: 3988
A year and a half brings about a lot of change. lol I traded in my '06 300C for an '07 CSRT8, installed my old bags on my buddy's 2007 Charger, and after riding around on Sportlines on the SRT for about a year, I'm going to be back on bags this weekend! Reading through this old thread brought about some great memories (and some bad ones too lol), but two air ride installs and two spring installs later, my confidence is obviously quite a bit higher than the first time I ever tore down an LX. Can't wait! I'll post new pics of the SRT8 this weekend.
The old C:
My buddy's Charger with my old UAS kit:
The SRT8 as it currently sits:
Flip flopped wheels. Here's the passenger side:
Simans82 is offline
Old 08-30-2009, 12:43 PM   #464 (permalink)
Simans82's Avatar
Member Number: 3988
Finished up! Here are a few pics.
Simans82 is offline
Old 08-30-2009, 12:45 PM   #465 (permalink)
Simans82's Avatar
Member Number: 3988
And a quick vid:
Simans82 is offline
Old 08-30-2009, 05:30 PM   #466 (permalink)
Points: 4,308, Level: 1 Points: 4,308, Level: 1 Points: 4,308, Level: 1
damageinc's Avatar
Car: 2007 Chrysler 300c marine blue pearl
Member Number: 12409
Lookin good Siman.....
damageinc is offline
Old 08-30-2009, 08:59 PM   #467 (permalink)
Simans82's Avatar
Member Number: 3988
Haha! Thanks brother!
Few install pics.
Tank and compressors in the spare tire well:
Mounted to rubber pieces that were fastened to the board prior to carpeting:
Bulkhead fitting that allowed the hose feeding the rear valve block to entire the spare tire well:
Other side of the bulkhead fitting:
Front valve block:
Rear valve block:
This is where the hose coming from the front valves enters the car:
New UAS billet front mounts:
And for those of you wondering what an air leak looks like while spraying everything down with soap and water, here it is.
Simans82 is offline
Old 09-05-2009, 11:34 PM   #468 (permalink)
Simans82's Avatar
Member Number: 3988
Few more pics.
Aired all the way up:
Thought this looked kinda crazy:
Laid out:
I went with the 7 switch this time around. Much smaller than the 9, and I can still go side to side by hitting individual corners:
Some silver love:
Back to black:
Simans82 is offline
Old 09-15-2009, 07:25 AM   #469 (permalink)
Points: 8, Level: 1 Points: 8, Level: 1 Points: 8, Level: 1
Car: 2004 VW Bug
Member Number: 23792
That's looking awesome! Can you tell me one thing? Are the door mouldings literally stuck on, or did you require welding to give the doors (sides) a smoothed out look?
darylbenfield is offline
Old 09-15-2009, 12:16 PM   #470 (permalink)
Simans82's Avatar
Member Number: 3988
Thanks for the comments! The door moldings are simply double-sided taped on. There is the possibility of paint/clear issues when removing them though. Most don't have any issues, some do. I haven't had problems with either of my LX's, nor did my buddy with his Charger. Although, you still might want to use the search function and search "demolding" or "removed molding" to gather some more info. Good luck!
Simans82 is offline
