Old 03-24-2007, 07:46 AM   #1 (permalink)
Points: 2,481, Level: 1 Points: 2,481, Level: 1 Points: 2,481, Level: 1
Car: 2006 300C Chrysler
Member Number: 4275
Squeaks over bumps!!!
Ok now im getting frustrated. There was a post a while back about squeaks and lubing up suspensions. So i tried the WD 40ing at all nuts and bolts in the front right suspension area (where it squeaks), didnt work. I cant take it to the dealer cus im over my warranty so anyone with the same problem? can anyone relate? i want to get rid of this noise!
o ya the sound is like an old bed making squeaky noises... dont ask me how its making squeaky noises... u can use ur imagination
bigboychoi is offline
Old 03-24-2007, 08:44 AM   #2 (permalink)
Member Number: 232
I developed a front end squeak with my hotchkis sway bars. It would consistently squeak when I drove over speed bumps. A lube job by the dealer eliminated the squeaking.
Below is a pic of hotchkis sways and bushings. The sways come with zerque lubricating fittings for the bushings.
joey is offline
Old 03-24-2007, 05:43 PM   #3 (permalink)
Member Number: 4275
If you lubed up all the nuts and bolts already. I would lube the bushings, the different connections in the joints etc. To me it sounds like your rubbing some dry rubber somewhere causing the sound.
would you happen to kno where? theyre like 5 or so nuts and bolts i saw... but dunno where else to spray...
Old 03-24-2007, 09:20 PM   #4 (permalink)
Member Number: 4275
I don't have any pics. But I would spray the strut mounts, the sway bar bushings and any other peices up there. It isn't just bolts, some of it could just be rubber mounting for other suspension components.
Just curious but you're profile says you have a 06' and this would be covered under your warranty, do you have a lot of miles on your vehicle that would cause your warranty to be over? If that is the case then this could have a different solution also.
haha yes its an 06... but i got it in may 05. and im at 40,000 miles.... but the squeaking started at 20,000 miles and the dealer said they coundnt hear the squeaks... ill try spraying it tomorrow... lets see.... but hopefully someone could really help me out on this....
Old 03-24-2007, 09:44 PM   #5 (permalink)
Points: 3,417, Level: 1 Points: 3,417, Level: 1 Points: 3,417, Level: 1
Car: 2008 Chevrolet Trailblazer SS
Member Number: 2873
ive had the sway bars in for about a month and so far so good. but i still get a creak that sounds like its coming from the left front. if you figure something out, do tell!
ilmanzo31 is offline
Old 04-15-2007, 12:35 AM   #6 (permalink)
Member Number: 4275
im still getting the squeaks...
Old 04-16-2007, 11:36 AM   #7 (permalink)
Member Number: 5047
Have you done anything to the suspension on the car?
-Zack Ratcliff
800-864-2470
Old 04-16-2007, 08:09 PM   #8 (permalink)
Member Number: 4275
nothing still stock.... should i? its just coming from the right front area... FOR SURE its coming from there... now it happens when i drive at any speed... the squeaks i mean... and the weird rubber rubbing noise while slightly braking and turning... you got answers?
Old 04-17-2007, 05:06 PM   #9 (permalink)
Points: 1,515, Level: 1 Points: 1,515, Level: 1 Points: 1,515, Level: 1
Car: 2006 chrysler 300c
Member Number: 11704
have exactly the same sounds, creaks when turning right with the brake on at low speed, will creak when standing turning lock 2 lock, under warranty dealer is changing both bottom arms on tuesday to see if thats the problem, they suspect dry bushes!
mikedaboss is offline
Old 04-18-2007, 12:58 AM   #10 (permalink)
Member Number: 4275
oooo do repost and tell me... those little suckers! soo much work to change those out by myself....but thats what im thinking also... but do u also get squeaks when you drive? over bumps?
