Old 04-12-2007, 08:39 AM   #1 (permalink)
Points: 2,632, Level: 1 Points: 2,632, Level: 1 Points: 2,632, Level: 1
The Trophy's Avatar
Car: 2005 Chrysler 300c AWD
Member Number: 11716
Can't find any 300c AWD shocks
I have been looking everywhere to find After Market Shocks(damper) for my 2005 Chrysler 300c AWD but can't find any.
I just bought the Eibach pro kit and want another set of 4 shocks for them. I need to keep the stock and swap them for winter. It's much faster to just swap the complete shocks than just swap spring and redo the compression on the damper. Roads and Winter are very bad down here so it's almost a must!.
Im also looking to buy new 20" wheel's, they suggest using 245/45/20 tire but there's not much choice, I wounder if i use 255/45/20 will make a big of a difference.
thanks
The Trophy is offline
Old 04-12-2007, 08:45 AM   #2 (permalink)
Points: 11,617, Level: 1 Points: 11,617, Level: 1 Points: 11,617, Level: 1
phillips2024's Avatar
Car: 06 300 C AWD
Member Number: 6234
Send a message via AIM to phillips2024
thanks
welcome to the forums! i have been lookin for new suspension parts for my awd and yes it is hard. eibach makes the springs but doesnt make any dampers. my understanding is the only real kits for us awd guys are the kw v2's..which are coilovers (comes wit everythin) and the uas kit. other than that we really dont have anythin. if anyone else can chime in wit some better info please do!
2006 Chrysler 300C AWD
check out my site for pics and mods
My Cardomain
phillips2024 is offline
Old 04-12-2007, 09:35 AM   #3 (permalink)
Points: 10,884, Level: 1 Points: 10,884, Level: 1 Points: 10,884, Level: 1
NotYet's Avatar
Car: 2007 Chrysler 300C
Member Number: 9392
Welcome aboard The Trophy. I don't have an AWD so I don't have much info for you. As far as tire sizes for 20" wheels, 255/45/20 is the stock tire size for the SRT so you might find a few more options out there. Check out tires-easy.com for some of the best tire prices around.
BigBob has an AWD - hopefully he can point you in the right direction regarding suspension work (fwiw, he's running the UAS air-ride kit).
Again, welcome to the forum. Make sure you go here and tell us a little more about yourself and your ride: New Member Introductions and Assistance
15% tint all around
KWv2
Startech grill
Clear side markers
Stealth bulbs
Interior LED bulbs
Demolded / Debadged trunk
Visor Disguisers
Hotchkis sway bars
SRT spoiler
RainX Latitude wipers
Tinted tail lights
NotYet is offline
Old 04-12-2007, 10:01 AM   #4 (permalink)
Points: 4,727, Level: 1 Points: 4,727, Level: 1 Points: 4,727, Level: 1
Member Number: 6648
Trophy,
I've also got an AWD and like Phillips2024 mentioned we only have two choices the KW V2's or UAS. The best tires size for 20's is going to be 255/45/20 and there are some options out there for that tire. Keep in mind that you're going to need 20's with a high offset. The three wheels that I'm looking at right now are the TIS 02's, The Verde Shiv, and the Zinik Caroza. I still undecided, but I'm leaning towards the TIS 02's. For those of us that have AWD the choice of wheels is limited. I hope this helps you out.
CSand78 is offline
Old 04-12-2007, 10:16 AM   #5 (permalink)
The Trophy's Avatar
Yes thanks, Im actually considering buying the Menzari MSC04 20" with the +45 offset. Thanks for the info on the tire, i will look for 255 instead, they have nice khumos for cheap.
Thanks for the heads up
