Old 04-12-2007, 05:38 PM   #1 (permalink)
Points: 5,240, Level: 1 Points: 5,240, Level: 1 Points: 5,240, Level: 1
frankieo's Avatar
Car: 2005 chrysler 300 limted
Member Number: 11578
Rear End Sway
Just Like To Know If The Problem I Have With My Rear End ,is Putting In A Sway Bar.when At High Speed And Hit A Bump Rear End Sways Alot.would Installing A Sway Bar Help.
frankieo is offline
Old 04-12-2007, 06:51 PM   #2 (permalink)
Points: 6,061, Level: 1 Points: 6,061, Level: 1 Points: 6,061, Level: 1
1fastsedan's Avatar
Member Number: 5972
Trader Rating: (4)
If by sway you mean body roll, as in the wheels are firmly planted but the rest of the car rocks back and forth - then yes a rear sway bar should help. If you're looking to do just the rear, there is a Mopar police package rear sway for $110. If you're looking to upgrade your front and add the rear, then you're talking Hotchkis around $350, Eibach around $325, or the new Mopar kit which I haven't seen a price for. Whichever part you choose, you will also need new end links for the rear as the V6 models don't come with rear sways from the factory.
1fastsedan is offline
Old 04-13-2007, 12:10 PM   #3 (permalink)
frankieo's Avatar
thanks for the information.see what happens in the future with install.
frankieo is offline
Old 04-27-2007, 01:54 AM   #4 (permalink)
Points: 3,113, Level: 1 Points: 3,113, Level: 1 Points: 3,113, Level: 1
Car: 2006 chrysler 300C
Member Number: 9648
My problem is too much vertical motion of the car up and down over the bumps on high speeds .. pro kit or sway bars or shocj absorbers should solve this problem ? My car is a 300C 2006 with only 11000 miles ...
nazab is offline
Old 04-27-2007, 02:33 PM   #5 (permalink)
1fastsedan's Avatar
Member Number: 5972
Trader Rating: (4)
You're talking about a shock/spring issue then. If you have >/= 50,000 miles on the car, I would replace the shocks. If its a new stock set-up you're not happy with, then you're looking at upgrades such as the SRT8 suspension or coil-overs like the Mopar kit, KWs, or Eibachs.
Old 04-27-2007, 02:44 PM   #6 (permalink)
Administrator
Points: 105,145, Level: 1 Points: 105,145, Level: 1 Points: 105,145, Level: 1
Northern Rider's Avatar
Member Number: 538
What make of tires are on the car? If they where the OEM Continentals, their sidewalls were too weak for the suspension on the 300.
Goodyear Comfort treads will improve the feel significantly.
Northern Rider is offline
