Old 04-25-2007, 09:42 AM   #11 (permalink)
Points: 4,033, Level: 1 Points: 4,033, Level: 1 Points: 4,033, Level: 1
Member Number: 7149
Originally Posted by Radarmagnet View Post
I've heard this was necessary but I never did it... I could see where dropping the whole cradle might cause alignment issues, but I haven't seen any evidence. Maybe I'm lucky (or stupid... or both!)
I will get a full alignment when my TIEN coilovers get on there!
Yeah, I suppose you could screw up the alignment, but I would think its more likely messing with the front bar. I can tell you mine is still perfect after swapping out the front. I swapped it out while I had the car up on ramps changing the oil. I just made sure I positioned the Hotchkis bar evenly when I installed it before I fully tighten all the hardware.
Chase300 is offline
Old 04-25-2007, 12:44 PM   #12 (permalink)
Points: 4,376, Level: 1 Points: 4,376, Level: 1 Points: 4,376, Level: 1
Member Number: 3745
I have just the Hotchkis bars as a suspension mod, and I agree with all of the above.
How much RWHP did this net you?
jimt
Cool Vanilla 2006 300C Build 09-05
Predator! CAI 93 tweaked with more fuel / Airaid CAI
Custom FanMod (The one that I use) / Custom FanMod (Simple Version)
Hotchkis Swaybars / SRT8 Suspension
Magnaflow CatBack (customized by MF)
JimTurner is offline
Old 04-25-2007, 12:52 PM   #13 (permalink)
Points: 2,280, Level: 1 Points: 2,280, Level: 1 Points: 2,280, Level: 1
Car: 2006 R/T Charger
Member Number: 4161
Well, after emailing Hotchkis for some stickers (which they sent) I have them listed on the Engine cover (along with Dynatech, Magnaflow, Superchips and K&N stickers)...
I'd say the sticker alone is worth 5HP.
RadarmagneT
2006 Red Charger R/T...
Dynatech Head&Cats, Magnaflow, K&N, Hotchkis Sways, AutoHeadlight, roof RD power, Flashpaq, NoESP.
Radarmagnet is offline
Old 05-02-2007, 11:43 AM   #14 (permalink)
Points: 4,211, Level: 1 Points: 4,211, Level: 1 Points: 4,211, Level: 1
Haywood's Avatar
Car: 2008 BMW 135i Coupe
Member Number: 5640
I put the Hotchkis' on when I did my exhaust. The rear bar is not so easy and you really should find a lift if you can. Both wheels need to be taken off and in my case, we had to drop the suspension. Definitely doable without a lift, but it's going to take you alittle longer. As stated, it will make a world of difference. If you ever want to take your car on an auto track, this is a MUST.
Haywood
Former SRT-8 Owner
2008 BMW 135i Coupe
Haywood is offline
