Old 05-12-2007, 10:16 PM   #1 (permalink)
Points: 2,391, Level: 1 Points: 2,391, Level: 1 Points: 2,391, Level: 1
Car: 2005 chrysler 300c
Member Number: 9547
How To Take Of The Rear Springs
can Any One Help Me... I'm Having Trouble Trying To Remove The Rear Springs.. Any Help That I Can Get Would Be Great
mikey's300c is offline
Old 05-12-2007, 10:29 PM   #2 (permalink)
Member Number: 9547
yeh thank i seen that threat.. but i cant find a shop that thas that single higed syyle coil compressor... try to see if their is a other way
Old 05-13-2007, 01:17 AM   #3 (permalink)
Points: 7,939, Level: 1 Points: 7,939, Level: 1 Points: 7,939, Level: 1
Tork Monster's Avatar
Car: 2006 Chrysler 300C SRT-8
Member Number: 6292
Hey Mikey,
That was my thread, and I have to say the rear springs were a beatch. I ended up making 5 trips to finally finish the install.
I found the smaller hinged-type compressor at a locally owned tool rental shop. The Schucks and other chain stores won't have the right kind.
I actually broke the compressor half-way through and returned it. Then I couldn't find another so I went back and begged to get it back and fix it. I knew the owner from High School, or I wouldn't have been able to swing that one (any normal shop would never loan out a damaged tool in fear of the liability if something went wrong).
I would suggest you call around the Mom & Pop tool rental shops and you may find the right one.
It makes me wonder what the professional shops use; these are popular cars to get lowered & it's done all the time! Maybe there is another way?
Good luck!
Jay
just kruzin' . . . . . Jay
Tork Monster is offline
Old 05-17-2007, 03:01 PM   #4 (permalink)
Points: 1,667, Level: 1 Points: 1,667, Level: 1 Points: 1,667, Level: 1
Car: 2006 Dodge Magnum SXT
Member Number: 10439
When I lowered my car, I thought the rears were gonna suck. Turns out they were easier than the front. Jack the car up and place on stands. Use your floor jack to support the center of the rear end. Work on one side at a time and remove the large 18 mm bolts, one in front and one in rear. SLOWLY, lower the jack. The one side will drop far enough to remove the spring without the need of any compressors. Do not lower it any more than needed. If you remove the bolts on both sides at the same time you will need an alignment to correct the angle in which the car drives. This may seem a bit weird, but it works.
brandon_williams_4 is offline
Old 05-17-2007, 03:05 PM   #5 (permalink)
Points: 3,855, Level: 1 Points: 3,855, Level: 1 Points: 3,855, Level: 1
kenm's Avatar
Member Number: 4621
Just take the four bolts out of the rear sub-frame and lowwer it with a jack. You will not need to use a spring compresser to do the job and it makes it a snap.
Kicker Sub
50% tint front 35% tint rear
SS grill & Radiator shourd
JBA headers
Modified air intake
Corsa Exhaust
HHP Hi-Flow Cats
Superchips FlashPaq
Cross Drillled Rotors
Hotchkis sway bars & KW VII's
Clear Side Markers
96' Dodge Intrepid
kenm is offline
Old 05-17-2007, 03:48 PM   #6 (permalink)
Points: 7,692, Level: 1 Points: 7,692, Level: 1 Points: 7,692, Level: 1
USMCSGT's Avatar
Member Number: 10501
Yup, no spring compressor needed for the rear. The direction posted in the LX forums shows you exactly how to lower the rear end to where the spring just falls out. I did it exactly how the write up says and it went smooth.
Mods:
35% Tint
Debadged
Demolded
22" Devino Staminas with Hankook 265/35/22 tires
6000K HID
Chrome Mesh Grill
"BLACKOUT" Vanity Plate
Eibach Pro-Kit
Halo headlights
Chrome bulbs
Color matched pillars
Color matched bumper inserts
Color matched medium tinted taillights by Jons Tinted Tails
Color matched medium tinted side markers by Jons Tinted Tails
Future Mods:
USMCSGT is offline
Old 05-17-2007, 04:05 PM   #7 (permalink)
Member Number: 6292
Great info!!!
Man, I wish I knew this when I did my install. I am going to do this again anyway to further lower the rear, so I'll take pics and revise my TTR procedure.
Ain't this place great?
