Old 06-07-2007, 01:48 AM   #1 (permalink)
Points: 2,050, Level: 1 Points: 2,050, Level: 1 Points: 2,050, Level: 1
Member Number: 8523
Send a message via MSN to DOKEY
Lightbulb Question For Anyone with Air Ride
Just curious if anyone had removed the inner fenders to have their car drop lower in the front and rear?
Thanks,
Chris(Dokey)
DOKEY is offline
Old 06-09-2007, 12:37 AM   #2 (permalink)
GROUNDED's Avatar
Member Number: 10038
the inner fenders arent whats holding up the car...
First would be the bags bottoming out. If you could modify the struts to get more travel then the wheels would hit the wells. this can be rectified by raising the strut towers or building a tubular front clip and core support. The other option to get lower then bags is juice. Juice usually gets you lower in cars then bags.
GROUNDED is offline
Old 06-09-2007, 06:07 AM   #3 (permalink)
Points: 2,999, Level: 1 Points: 2,999, Level: 1 Points: 2,999, Level: 1
Member Number: 5379
With the front of the 300c the upper control arm hitting on the strut tower and the fact the balljoints are nearly at bind it what is stopping you going any lower at the front
The rear is the shock length
It needs to be 20 to 30mm shorter
But once you go lower then the drive shaft hits on the cradle support that holds the diff centre
You can only go as low as the car will allow
Juice on a 300c won't get you any lower than bags
Tubular Suspension is offline
Old 06-09-2007, 09:55 PM   #4 (permalink)
Blowndakrt's Avatar
Member Number: 1851
Thanks,
Chris(Dokey)
What tires are you running? I am currently looking into removing and modifying (sp?) my inner fenders to do just that. When I go to 24's the tires will hit before the suspension will bottom out, since it will be the same overall diameter I am currently running.
There are a few on the forums that have done it. They should chime in fairly soon to give you a better insight on what needs to be done.
Shawn
Blowndakrt is offline
Old 06-11-2007, 04:47 PM   #5 (permalink)
Member Number: 5047
Thanks,
Chris(Dokey)
On these cars they cut out for the upper arm and raised the inner fenders sheet metal to clear out for the tires. Both of these are on 24's
-Zack Ratcliff
800-864-2470
Old 06-11-2007, 05:05 PM   #6 (permalink)
Points: 3,175, Level: 1 Points: 3,175, Level: 1 Points: 3,175, Level: 1
LAYN300's Avatar
Car: 05 chrysler 300
Member Number: 5311
please dont answer if you know nothing about the topic... the bags dont bottom out nor does juice get you lower.... the upper arm in front is whats restricting the drop as well as the tires hitting the pinch molding and few other spots up front... the back needs new shocks and a few notches cut out for arm movement. ...........juice will help you get more lift tho
LAYN300 is offline
Old 06-11-2007, 05:12 PM   #7 (permalink)
Points: 5,893, Level: 1 Points: 5,893, Level: 1 Points: 5,893, Level: 1
Car: 2005 Chrysler Brilliant Black 300C
Member Number: 10951
Send a message via AIM to D's300C Send a message via Yahoo to D's300C
those whips look dope.
D's300C is offline
Old 06-17-2007, 06:11 PM   #8 (permalink)
Points: 1,657, Level: 1 Points: 1,657, Level: 1 Points: 1,657, Level: 1
highrexpctations's Avatar
Member Number: 10179
highrexpctations is offline
Old 06-22-2007, 03:16 AM   #9 (permalink)
Points: 2,521, Level: 1 Points: 2,521, Level: 1 Points: 2,521, Level: 1
300onBags's Avatar
Member Number: 12729
Send a message via AIM to 300onBags
I did not cut my inner fenders front or back. the back does not touch the inner fender and the front just barely rests on the inner fender. I have 22's with 265/35/22 tires and have no problems and soon i will have 24's
2006 Midnight Blue/Oriental blue candy 300 w/graphics
Mods:
24" KMC Dimes
Bagged
Blue Ostrich leather
35% mirror tint
shaved door handles/de molded
de badged
Clear LED taillights
Grey marbleized wood grain
Nu images diamond gauges
Chrome mesh grill/grill for fog lights
Diamond door locks/license plate bolts
GOTBAGS Vanity plate
Indash tv
(1)12" kicker
400w Kicker amp
painted ac knobs,side morror adjust,seat controls and lumbar support
6 shooter billet shifter
plus more
300onBags is offline
Old 06-22-2007, 05:58 PM   #10 (permalink)
mine is tubbed back and front, no more factory fenderwells(spelling)
