KW V2 and Hotchkis Install Price
For those of you who have had your KW's installed by professionals, how much did you pay? I called around and it seemed like nobody wanted to do the job, but I finally found two people to do it and one said it was a 5 hour job and the other said a 8 hour job. Of course I went with the 5 hour guy, plus his shop was a lot more professional and they did a good job. However I eneded up being charged for 8 hours because he said the rear sway bar for the touring is a SOB since it doesnt come with one stock. And to make fine adjustments on the rear you have to take the shock out just to be able to adjust it, so it ended up taking 8 hours. I'm not sure it really took them this long since a lot of you did your own install in about 6 hours in a freakin drive way, but whatever. So the final cost was $800 for me, but I also brought in my parts instead of buying through them since I got a good deal from our supporting vendors. Just interested in the amount you all payed, please state your labor rate, what you had done, and if you bought your parts yourself or from them. Thanks a lot and I will get some pics up of the 22's tucked when it stops raining and I wash the bad boy.
