Old 08-29-2007, 10:23 AM   #11 (permalink)
jasonb20's Avatar
Car: 2007 CHYRSLER 300C
Member Number: 13617
I would go with some H&R springs. Had them before and you wouldn't regret them. They are german engineered and used on many racing cars in the states and Europe. STAY AWAY FROM COILOVERS!!!!!!
jasonb20 is offline
Old 08-29-2007, 12:27 PM   #12 (permalink)
MADDOG`'s Avatar
Member Number: 11602
I haven't heard any negative remarks on coilovers. Now, most of the folks that have installed them went with the KW V1's or V2's or the MOPAR coilover kit (KW V1's) and were very pleased, even over time and mileage, with the performance.
So what's wrong with coilovers in your experience? Just curious as I am seriously contemplating doing them.
MADDOG` is offline
Old 08-29-2007, 12:36 PM   #13 (permalink)
Hardder Performance's Avatar
Car: 2006 chrysler 300c SRT8
Member Number: 7108
Send a message via Yahoo to Hardder Performance
As I have never heard anything bad about the kw variant 2!! all responses i have heard have been that they are the best for our srt8 applications!!!
2006 300c SRT8 brighliant black,every option!!
Car Name= Black Sunshine
1. Corsa cat-back
2. Mopar (dub) chrome mesh grille
3. DubAir air intake system
4. 5% tint on 5 windows and 15% on windshield
5. Airraid tbs
6. Jet stage 2
7. Crystal clear black tails
8. 180 degree thermostat
9. Bf Goodrich G- Force kdw2 265/30/20
Hardder Performance is offline
Old 08-29-2007, 12:41 PM   #14 (permalink)
Member Number: 7108
Maybe youv'e been in acoma for the past 5 years,,so i'll let you in on a little secret!!! springs are the cheap way around a n excellent ride!! coilovers that are designed for our applications are the best way to get a drop for performance rides. (Your weakest link is your strongest point)
1. Corsa cat-back
5. Airraid tbs
6. Jet stage 2
Old 08-29-2007, 12:43 PM   #15 (permalink)
MADDOG`'s Avatar
Yup! X@
LOL...but I am interested in hearing the opposing viewpoint.
MADDOG` is offline
Old 08-29-2007, 05:39 PM   #16 (permalink)
Member Number: 7108
I Am Hoping You Are On My Side There Maddog?? Eh Eh
1. Corsa cat-back
5. Airraid tbs
6. Jet stage 2
Old 08-29-2007, 07:32 PM   #17 (permalink)
MADDOG`'s Avatar
Everything I've heard supports your position, bro!
I've never heard anything negative about coilovers except once a fella put the wrong ones on his 300ZX and had all kinds of trouble...but it was his fault, not the fault of the parts.
So, I'm leaning your way!!!
MADDOG` is offline
Old 09-06-2007, 09:57 PM   #18 (permalink)
JusticePete's Avatar
Car: 2005 Chrysler Pacifica
Member Number: 10746
I must be lost. Don't all SRT8 have Nivomat rear dampers? The only way to lower a Nivomat vehicle is to replace the rear coil and shock. What did I miss?
Pete Basica
www.PeddersUSA.com
JusticePete is offline
Old 09-06-2007, 10:57 PM   #19 (permalink)
Car: 2007 Chrysler 300C SRT8
Member Number: 12960
Coilovers (or a matched spring/shock set), if properly engineered, are superior to lowering springs.
When you install stiffer springs, you generally need less compression and more rebound on the shocks. If the shocks and springs are mismatched, handling and ride quality will suffer.
People often confuse reduced sway with better handling. Reduced sway is just one piece of the puzzle. Wheel control is at least as important, and the right spring rates and shock valving are critical for wheel control.
Tim Skelton is offline
Old 09-06-2007, 11:02 PM   #20 (permalink)
1fastsedan's Avatar
Member Number: 5972
Trader Rating: (4)
You didn't miss anything. I said that earlier, but some people don't want to hear it. They'll put the springs on and then the rear will still be up in the air...
1fastsedan is offline
