Old 07-06-2007, 10:53 AM   #1 (permalink)
Member Number: 12500
Lowering Springs for 06 SRT8
I just got done picking up my car from Les Schwabs and the Eibach Springs would not fit on my SRT 8! Is there any springs available to put on the SRT 8's?
deannacario is offline
Old 07-06-2007, 12:26 PM   #2 (permalink)
Any help, Eibach said they don't make anything that works with the SRT8 model!
Old 07-06-2007, 01:23 PM   #3 (permalink)
1fastsedan's Avatar
Member Number: 5972
Trader Rating: (4)
Hotchkis makes an SRT8 set. You better make sure you don't have Nivomat self-leveling shocks in the rear though, or no lowering springs are going to work. I don't know of any SRT8s without the Nivomats, thats why most move to coilovers instead of lowering springs.
Domestic Car >> Chrysler >> 2005-2007 300C SRT8 300C SRT8 Sport Coil Springs
Item# 19105
Retail Price: $306.95
When we decided to manufacture coil spring for the 300C SRT8 we took our time and researched other springs on the market. With those springs in mind we found a great combination of performance and comfortable ride characteristics. Our springs feature a linear rate design, and come complete with urethane bump stops.
Note: Not for vehicles with load leveling suspension
Spring Rate:
Front: 280lb
Rear: 650 lb
300C SRT8 Drop:Front: 1/8" Rear: 5/8"
Charger SRT8 Drop : Front: 1/4" Rear: 3/4"
1fastsedan is offline
Old 07-09-2007, 04:19 PM   #4 (permalink)
Thanks 1FastSedan! It looks like you have a SRT8. I'm very new to upgrades to vehicles! But, what coilovers would be best if I do have the leveling rear end? Would I have to get springs that fit the coilovers or the just the coilovers alone? Thanks for the info!
Old 07-10-2007, 09:34 AM   #5 (permalink)
1fastsedan's Avatar
Member Number: 5972
Trader Rating: (4)
Coilovers include both the shock/strut and springs. There are several different brands available: Mopar, KW (version 1 and 2), ST Suspensions, Eibach and TEIN. With the exception of TEIN, they're all made by KW.
Old 07-10-2007, 12:04 PM   #6 (permalink)
StealthAuto's Avatar
Car: 99-06 Ford Mustang Cobra, 700HP Vespa, Range Rover, future SRT-8
Member Number: 6435
Trader Rating: (13)
KW V1 Coilovers are a great upgrade. Hotchkis springs will also work.
StealthAuto is offline
Old 08-05-2007, 02:07 PM   #7 (permalink)
Car: 2006 300 SRT-8
Member Number: 10426
so you can use the hotchkis springs and not get the coil overs? 1500 just seems a bit much to be able to lower your car..
nmorale3 is offline
Old 08-10-2007, 05:55 PM   #8 (permalink)
Member Number: 12783
Springs only = Bounce
If put lowering springs on without a shock designed to work with those springs, you can expect some unpleasant side-effects. I just tried this, my car bounces like a low-rider Impala and hits bottom. I am going back for KWs next week. Save yourself some labor costs and disappointment and get the KWs.
SHOMan is offline
Old 08-17-2007, 04:39 PM   #9 (permalink)
KWs = MASSIVE RIDE IMPROVEMENT
Got the KWs on. They made all the difference. Only one bounce per bump now. Cornering is truly SICK. I did raise it up .5 inches all around, but once it settles it should be perfect. The lowering springs alone looked better, but the handling was poor.
Well worth the money, especially if you add in the cost of replacing stock shocks when they blow in six months.
SHOMan is offline
Old 08-28-2007, 02:00 PM   #10 (permalink)
Hardder Performance's Avatar
Car: 2006 chrysler 300c SRT8
Member Number: 7108
Send a message via Yahoo to Hardder Performance
I am thinking hard about the addition of the kw 2's. I just put on a set of 265/30/20 bf goodrich g-force kdw 2's those tires are f'in awsome!!! but they leave to much of a fender gap!! so i am asking for a good place to buy the set of kw 2's from at the best price? and ,,,how much did you get charged for installation??
2006 300c SRT8 brighliant black,every option!!
Car Name= Black Sunshine
1. Corsa cat-back
2. Mopar (dub) chrome mesh grille
3. DubAir air intake system
4. 5% tint on 5 windows and 15% on windshield
5. Airraid tbs
6. Jet stage 2
7. Crystal clear black tails
8. 180 degree thermostat
9. Bf Goodrich G- Force kdw2 265/30/20
Hardder Performance is offline
