Old 08-29-2007, 04:40 AM   #1 (permalink)
1bad06's Avatar
Car: 2006 Chrysler 300
Member Number: 3708
front end making a popping sound
Hey every one I was wondering if any one can tell me why I am getting poping sound when I turn my wheels. I just put a new set of 22's on last friday. I had 22's on it before and I didn't have any problems. It only happens when I turn my wheels left or right when backing up to park (I always back in). Not sure if it is the weights on the lip of the inside of the rim hitting the control arm. i put my hand back behind the rim where they meet the control arm and there isnt any room feels like the rims is up aagainst the bar. So i pulled one of the rims off to see if there was any scratches on the rim and there wasnt any. i was amazed that the wheels turn since they are so close to the control arm.
I ordered the KYB GR-2 shocks on Friday they will be here next week. I hope that will help. Unfortunatly they dont make a shock for the rear so I will have to go with a different brand (Monroe Sensa-trac) I think that I will wait to replace the rear.
1BAD06
Eugene
Vice-President and Co-Founder OF
"Northern Va 300 Car Club"
1bad06 is offline
Old 08-30-2007, 10:25 AM   #2 (permalink)
Member Number: 5047
If its a grinding noise it is the wheel nicking the spindle. It only does it in reverse because the car has alot of negitive caster when going forward (for that good handling), but when its in reverse its alot of positive caster. With the little bit of flex its just enough to cause the wheel to hit the spindle. What i did on mine to fix this is to slightly grind (about 1/10 of an inch) the spindle right where the wheel is and the noise is gone.
-Zack Ratcliff
800-864-2470
Old 08-31-2007, 04:47 AM   #3 (permalink)
1bad06's Avatar
Member Number: 3708
Thanks that exactly what is was I put the car in reverse and waited until i heard the sound stopped right there and looked under the wheel well and thqats what is was so I shaved off some metal on both sides with a grinder and the problem is solved!!!!!!!
Thank you for the response!!!!!!!!
1bad06 is offline
Old 09-06-2007, 09:02 PM   #4 (permalink)
JusticePete's Avatar
Car: 2005 Chrysler Pacifica
Member Number: 10746
Any chance you can post a picture?
Pete Basica
www.PeddersUSA.com
JusticePete is offline
