09-27-2007, 01:48 AM
#11 (permalink)
Car: 2005 Chrysler Pacifica
Member Number: 10746
Originally Posted by Top40
The rubber dust/boot cover that is on the original shock. It will not totally fit into the spring which was causing the fronts to squeak when I went over bumps. after I removed them the squeak stopped. I also read in another KW V2 forum that these should be cut off upon initial installation since they do not fully sit inside the spring.
Got it.
