Old 09-07-2007, 04:39 PM   #1 (permalink)
300CUL8R's Avatar
Car: 2005 Chrysler 300C SRT-8
Member Number: 1232
Noise with KW Variant 2 coilover?
A guy at my tire shop said he has concerns about additional noise with aftermarket coilovers.
Anyone install the KW V1 or 2 and experience this?
Thanks.
____________________________________________
2005 Silver 300C SRT-8
Magnaflow Exhaust
Mopar CAI
Diablosport Predator w/ GSM Custom Tune
Grip Grille
Ultimate Pedals
Chrysler VES
Tint - 35% all around
"Nobody tinkers with my tweeter." - Larry Dallas
300CUL8R is offline
Old 09-07-2007, 06:17 PM   #2 (permalink)
Member Number: 232
What kind of noise? I don't hear anything different with my V2's.
joey is offline
Old 09-07-2007, 08:05 PM   #3 (permalink)
3CF ADMINISTRATOR
Northern Rider's Avatar
Member Number: 538
No noise from the KW V2's here.
Just get the odd squeak from the Hotchkiss sways.
Northern Rider is online now
Old 09-07-2007, 08:28 PM   #4 (permalink)
JusticePete's Avatar
Car: 2005 Chrysler Pacifica
Member Number: 10746
Thanks.
If you don't change the strut mount I am not sure where the additional noise would come from. Could you ask him why he felt this way? He may know something we don't.
Pete Basica
www.PeddersUSA.com
JusticePete is offline
Old 09-07-2007, 10:13 PM   #5 (permalink)
300CUL8R's Avatar
Member Number: 1232
He seemed to think there was some sort of metal to metal contact that would cause a "clacking" sound. Not sure he knows what he's talking bout.
Do and of you SRT guys feel a significant difference over stock?
300CUL8R is offline
Old 09-08-2007, 10:24 AM   #6 (permalink)
We make coilovers -- not for the 300 - and I drive every day on my coilovers. There is no noise inherent in a coilover upgrade. There is noise is you replace the the strut mount and move to a spherical bearing metal castor / camber plate when you install a coilover there with be very different NVH characteristics with more road noise and vibration transferred directly to the body structure. I could be wrong, but I don't think the KX kit requires the use of these plates. There should be no additional noise.
Old 09-25-2007, 11:50 PM   #7 (permalink)
Car: 2006 Chrysler 300C AWD
Member Number: 11751
I had a slight squeaking noise on my AWD 300C...found out that it was the rubber boot located on the fronts...I cut it out completely and no more squeak...never a clacking sound
Top40 is offline
Old 09-26-2007, 12:07 AM   #8 (permalink)
...cut out which rubber boot?
Old 09-26-2007, 12:10 AM   #9 (permalink)
fatchance's Avatar
Car: 05 Silver 300c
Member Number: 422
I've had mine for over 2 years and have no issues what so ever. The KW V2 are the best.
fatchance is offline
Old 09-26-2007, 02:42 PM   #10 (permalink)
The rubber dust/boot cover that is on the original shock. It will not totally fit into the spring which was causing the fronts to squeak when I went over bumps. after I removed them the squeak stopped. I also read in another KW V2 forum that these should be cut off upon initial installation since they do not fully sit inside the spring.
Top40 is offline
