Fix for AWD Raked Stance - Chrysler 300C Forum: 300C & SRT8 Forums
» Auto Insurance
Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > Performance Forums > Suspension/Handling Modifications
Register Home Forum Active Topics (T) Gallery Insurance Garage Search Today's Posts Mark Forums Read
Suspension/Handling Modifications This section is for discussion of suspension related topics.
Old 09-10-2007, 06:21 PM   #1 (permalink)
Points: 1,023, Level: 1 Points: 1,023, Level: 1 Points: 1,023, Level: 1
Car: 2005 Chrysler 300C AWD
Member Number: 14036
New guy here, I picked up my 05 AWD earlier this year. The stance has always bugged me. I'm an old school hot rodder at heart but the 300 was never ment to have the raked stance of yore.
A quick check with a tape measure showed the following distance to the top of the fender well.
Front 30.25" Rear 31.5"
Gap 2.25" 3.5"
With the stock 225/60/18 which are 28" tall you end up with the gaps listed above.
Being the hands on kind of guy that I am, I decided to dig into the rear suspension and see why it was higher than the RWD models. When I pulled the rear springs I quickly found that there is very little difference from the RWD models. In fact they are identical right down to the springs which had a tag with big "RWD" lettering on them. I checked out the front springs and sure enough they had "AWD" on them. My best guess is that the huge by large spring isolaters are responsible for the ride height difference. The lower isolator looked like a spring isolator should and was about 1/4" thick. The upper isolator was at least 5/8" thick.
I then replaced both the upper and lower spring isolators with a length of 5/8" heater hose slipped over about half a coil. This will ensure no squeeking problems on down the road. With the rear suspension buttoned back up I was greeted with an 1.5" drop. The new ride height is right at 30". This is slightly lower than the front and is hardly noticable at all. Although I may replace one of the front isolators with the heater hose to get about a 1/2" drop.
The rear wheel well gap is now even all the way around the tire. This is really what I'm after as I'm not interested in that "slammed" look.
Can some one with a RWD 300c take some measurements of their fender well height? I would be interested in the specs for the SRT8 guys as well. What I would like to do is get an idea of what kind of wheel travel the chrysler engineers were going for with different spring and shock rates. I plan on figuring out what the stock spring rates are for various models and coming up with a plan to swap in some stiffer springs to allow a lower drop if thats your goal.
I've found that eibach has a very flawed design plan when it comes to choosing spring rates. Which is probably why several people are reporting limited shock life with them. I believe with the right factory springs cut to the proper length I should be able to come up with a cheap DIY lowering kit that any one can do themselfs. Before you guys jump to conclusions let me say that I'm more than qualified to do this and I'll walk everyone through my thought process as I do it. For a little background on me check out my introductory post in the newbi section.
AWD_Guy is offline
Old 09-10-2007, 08:23 PM   #2 (permalink)
Points: 1,275, Level: 1 Points: 1,275, Level: 1 Points: 1,275, Level: 1
madeulooq's Avatar
Car: 2006 chrysler 300c AWD
Member Number: 8250
I really want to see a pic of ur car...this sounds interesting.
MY BRICK CAN FLY, SO WHAT?
http://www.youtube.com/watch?v=vnOrB5iHJa0 {http://www.youtube.com/watch?v=723ph5QTNF8
MODS..AFE II, DIABLO PREDATOR & SRT EXHAUST.(INSTALLED)
Powered by INERTIA MOTORSPORTS/SVS(BOB)
madeulooq is offline
Old 09-10-2007, 08:27 PM   #3 (permalink)
Administrator
Points: 242,855, Level: 1 Points: 242,855, Level: 1 Points: 242,855, Level: 1
Activity: 43% Activity: 43% Activity: 43%
Rambit's Avatar
Car: 2005 300C SRT8
Member Number: 1493
I know I'm definately in the minority here, but that's the first thing I noticed about my car when viewing it from the side. I liked it!
I agree with you on the AWD it not looking good, but for me I love that rake on my SRT8.
Bernie
Click Here To Put Your Location On The 300cforums.com Member Map
Rambit is offline
Old 09-10-2007, 08:37 PM   #4 (permalink)
I'll get some pics up, I do like some rake, which is why I want to lower the front about 1/2". But the AWD has a crap load more than necesary. Plus the natural body lines of the car give you that raked stance. Just compare the front windows to the rears.
AWD_Guy is offline
Old 09-10-2007, 08:41 PM   #5 (permalink)
Administrator
Rambit's Avatar
Car: 2005 300C SRT8
Member Number: 1493
I just noticed this portion of your post! Please get some step by step pics as you go along. This would be a great DIY How-To post!!!
Bernie
Rambit is offline
Old 09-10-2007, 08:47 PM   #6 (permalink)
madeulooq's Avatar
Member Number: 8250
Bernie
^^^^really good idea
Old 09-10-2007, 09:01 PM   #7 (permalink)
Activity: 65% Activity: 65% Activity: 65%
bruno's Avatar
Member Number: 3129
I'm definitely with Rambit! I love the rake because it adds a touch of 'meanness' to the stance.
When I finally get the TEIN Suspension w/EDFC sooner than later, I will still want to have a little bit of rake to the 300c.
bruno is offline
Old 09-10-2007, 09:07 PM   #8 (permalink)
Administrator
Rambit's Avatar
Car: 2005 300C SRT8
Member Number: 1493
And yet on the other hand, I think the base models look good slammed, especially when demolded. I don't know why that is, but it seems to look good to me. Funny how the different models all have their own look, yet it's the same car...humm.
Bernie
Rambit is offline
Old 09-10-2007, 09:39 PM   #9 (permalink)
Points: 2,084, Level: 1 Points: 2,084, Level: 1 Points: 2,084, Level: 1
Irwin's Avatar
Car: 2005 sun roof, adjust. pedals. K&N drop-in filter. DRL enabled 300C silver
Member Number: 3872
Stance
I also like the stock stance/rake of my "C"
Irwin is offline
Old 09-12-2007, 07:11 PM   #10 (permalink)
Points: 2,662, Level: 1 Points: 2,662, Level: 1 Points: 2,662, Level: 1
4life's Avatar
Member Number: 12657
Hey keep us updated, Im not a big fan of the raked look either.
4life is offline
Aggressive Stance Thread driftsucky Chrysler 300 Picture/Media Post 374 03-14-2012 06:25 PM
300c AWD w/ 20" Factory Reproductions Charger AWD Replica Wheels drewmin Factory Reproductions Inc 5 05-07-2009 09:56 PM
pics of 20's / lowered stance on the C xodusphd Custom Wheels & Tires 3 08-19-2006 12:57 AM
New SRT8 Rims, Stance Pics Before Drop MR Bulk Custom Wheels & Tires 11 04-16-2006 11:15 AM
Break fix/shift fix call from dealer SRT8/BMW SRT8-Specific General Discussion 2 11-02-2005 10:18 AM
