Old 06-01-2008, 08:57 PM   #21 (permalink)
batwood's Avatar
Car: 2001 Dodge Durango
Member Number: 15186
The SPC one is a pressed in eccentric bushing with no adjustment once pressed in.
Our EP7277 Adjustables will allow you roughly a .9 degree range of motion in adjustability.
DFW Pedders Day June 8th
http://www.peddersusa.com/Dealers.ht...ed_Auto_Sports
batwood is offline
Old 06-02-2008, 02:17 AM   #22 (permalink)
gregLEV's Avatar
Car: 2005 Chrysler 300C 5,7l
Member Number: 15820
@ batwood:
PM sent
gregLEV is offline
Old 06-02-2008, 07:46 AM   #23 (permalink)
batwood's Avatar
Originally Posted by gregLEV View Post
@ batwood:
PM sent
PM returned. Let me know if you have any more questions.
batwood is offline
Old 06-12-2008, 04:31 AM   #24 (permalink)
gregLEV's Avatar
Hello,
does somebody have any other suggestions to improve the camber?
What about the camber correction bolts from Chrysler? Do they make sense?
I´m looking for a quick and easy solution...
Regards!
gregLEV is offline
Old 07-05-2008, 06:53 PM   #25 (permalink)
Justinlhc's Avatar
Car: 2007 Chrysler 300 Touring
Member Number: 18364
Originally Posted by doctorleevil View Post
I've got 22s not lowered. I went through 2 sets of tires already under 25k miles! I've only got the car for another year. Can anyone point me to a cheap camber kit? I dont want to have to get another set of tires.
Thanks!
I would think a simple alignment will solve your problems. I don't know why you would eat 2 sets of tires in less than 25k miles without being lowered.
Justinlhc is offline
Old 07-13-2008, 03:26 PM   #26 (permalink)
gregLEV's Avatar
Hi,
one question to all who already have installed the camber kit:
To install the bushings at the rear, do you have to disassemble the coils and the shocks as well? Uuh...that would be a lot of work
I would appreciate your help.
gregLEV is offline
Old 08-11-2008, 11:11 AM   #27 (permalink)
cpesloco's Avatar
Car: 2005 Chrysler 300c
Member Number: 18592
So will buying and installing this after market camber kit give me enough adjustment to stop my tires from wearing out on the inside? Will this be all I need to purchase?
cpesloco is offline
Old 08-12-2008, 11:18 AM   #28 (permalink)
JusticePete's Avatar
Car: 2005 Chrysler Pacifica
Member Number: 10746
It would help. It depends on the loaded ride height of your LX. If you measure your ride heights from the lower wheel lip (hook the tape measure there) up through the the wheel center to the painted edge of the fender with the vehicle empty and then do it again fully loaded we will know how much of a change there is in ride height. This will give us an idea of how much the camber change will be. Once we know that we'll know if one degree of adjustment will be sufficient.
Pete Basica
www.PeddersUSA.com
JusticePete is offline
