Old 12-19-2007, 06:54 PM   #11 (permalink)
Points: 2,576, Level: 1 Points: 2,576, Level: 1 Points: 2,576, Level: 1
Steve Levin's Avatar
Car: 2006 Chrysler 300 SRT-8
Member Number: 8841
Send a message via AIM to Steve Levin
As an update, I just got the replacement bushings today and had them installed; it appears to my untrained eye that one was totally unlubricated on the inside, and the other (less broken up) only lightly lubricated. I'm guessing that's indeed the issue.
Steve
Steve Levin is offline
Old 12-19-2007, 07:10 PM   #12 (permalink)
Points: 10,132, Level: 1 Points: 10,132, Level: 1 Points: 10,132, Level: 1
NYC_SRT8's Avatar
Member Number: 5993
Trader Rating: (18)
Steve
Thank God because I was starting to get scared. Thought I would have to drop the rear cradle again. I grease mine so much it should last forever...atleast I hope.
Best- 11.977 @ 116.01mph 1.745 60ft
Mods - DC sports strut tower bar - hid fogs - Billet Oil Catch-Can - Diablo Predator - Airhammer - Corsa cat-back - Inertia heads (big valve job), Inertia SRTMAX Hell cam, Inertia ported Intake manifold, Inertia CMR tune, Kooks longtubes (PM-FL coated), 1000hp shafts, Edge 3000k stall converter
NYC_SRT8 is offline
Old 12-19-2007, 08:40 PM   #13 (permalink)
Points: 156,835, Level: 1 Points: 156,835, Level: 1 Points: 156,835, Level: 1
Member Number: 232
This probably deserves it's own thread, but has anyone been successful greasing the rear sways after installation?
I tried greasing the rear hotchkis sways and I could'nt find an adapter that could fit in the tight space above the zerk fitting.
Hotchkis should have given us a 90 degree zerk fitting, like this one
Instead, Hotchkis gave us these vertical zerk fittings which doesn't give enough room to fit a grease adapater.
I tried a right angle grease adapter, similar to this pic, but I couldn't get it to work.
I have a grease gun like this pic. And it barely reaches the zerk fitting.
For anyone that is planning to install hotchkiss rear sways, buy 90 degree zerks, it will make it a lot easier to later grease.
I also tried this needle nozzle with some success, but it is not a good solution.
joey is online now
Old 12-19-2007, 10:55 PM   #14 (permalink)
Points: 15,933, Level: 1 Points: 15,933, Level: 1 Points: 15,933, Level: 1
Activity: 36% Activity: 36% Activity: 36%
BIG SMOOTH's Avatar
Member Number: 7757
Trader Rating: (8)
Steve
Good to know! I had them grease the hell outta mine on install.
"Stay classy San Diego!"
BIG SMOOTH is offline
Old 12-19-2007, 10:55 PM   #15 (permalink)
BIG SMOOTH's Avatar
Member Number: 7757
Trader Rating: (8)
Also good info. to know! Thanks!
Old 12-19-2007, 11:44 PM   #16 (permalink)
Member Number: 8841
Okay, excuse my ignorance...but the inside of the bushing should be lubricated, right? In other words, the round hole where the bar passes through. That's the portion that was unlubricated, and my assumption was that the bar simply tore it up by not being able to freely twist.
If you aren't supposed to lubricate in there, and just lubricate the outside, then I will be sad because I won't have a good clue why the first set failed
Steve
Old 12-20-2007, 04:00 AM   #17 (permalink)
Member Number: 232
Steve
Yes, the grease goes on the inside of the bushings. The rear sway bar zerk greasable fittings have a hole so the grease can reach the sway bar.
joey is online now
Old 12-20-2007, 07:52 AM   #18 (permalink)
Administrator
Points: 105,145, Level: 1 Points: 105,145, Level: 1 Points: 105,145, Level: 1
Northern Rider's Avatar
Member Number: 538
I purchased my sways 2 years ago. The earlier hotchkis sways (purchased maybe a year or more ago) had some problems with the front bushings being too tight. They started squeaking after about 6 months or so. Hotchkis sent me replacement bushings, and extra washers which I think helps protect the bushings.
Here is a pic of my old/original bushings after about 18k miles.
The bushings look like they held up pretty good, and no deterioration.
The second pic is the replacement bushings I received from hotchkis.
But my problem was squeaking, not thunking or banging noises.
I have the same issue with my front bushings. Thanks for this info, Joey. Time to give Hotchkis a phone call.
Northern Rider is offline
Old 12-29-2007, 01:59 PM   #19 (permalink)
Points: 932, Level: 1 Points: 932, Level: 1 Points: 932, Level: 1
batwood's Avatar
Car: 2001 Dodge Durango
Member Number: 15186
When ever you deal with urethane bushings it is imperative that you only grease liberally the rotational portion of the bush. Make sure that none gets on the load bearing surface as this will cause the bush to wander or walk out.
batwood is offline
Old 01-09-2008, 01:14 PM   #20 (permalink)
Points: 14,397, Level: 1 Points: 14,397, Level: 1 Points: 14,397, Level: 1
moddog's Avatar
Car: 2005 Build Date 08/24/04 Custom engine cover SS Hood cover SS E&G Grill Chrysler 300C
Member Number: 1965
Last week I gave them a call told them my busings were squeaking they sent me all 4. Today I replaced the front ones and I could see about 80 percent of the grease was gone. Hotchkis said the inside diameter was wrong and the grease will work it's way out.
Stock 300 rwhp 352 rwt
moddog is offline
