Old 12-23-2007, 11:45 PM   #1 (permalink)
Points: 4,256, Level: 1 Points: 4,256, Level: 1 Points: 4,256, Level: 1
chunk77's Avatar
Car: 2006 C 300
Member Number: 4164
Question Lowering Issue - Need Help
So I have a bit of a problem....the last couple of days I re-lowered my car and adjusted the KW V2's and put on 22" Asanti's and I have noticed when I take a sharp left hand turn i hear scraping on the rear right wheel. I mean it sounds like scraping or grinding of metal. Not sure if the tire is rubbing or something is loose with the exhaust. It just happens during the hard turn then stops. This is with only me in the car.
I thought it was the exhaust until today when I had 4 people (all 140 lb girls) in the car and on both right and left turns and some bumpy roads I heard the same type sound, so now I think it may just be my tires rubbing.
After I stopped I checked both rear tires and all I found was this really dark and thick gritty grease substance. Any idea what this is and what the noise is? Here are pics of the grease and it was up under the fenders of the rear wheel wells.
Funny thing is that my car isnt that low, it has room as you can see in the rear.
chunk77 is offline
Old 12-23-2007, 11:50 PM   #2 (permalink)
Points: 3,351, Level: 1 Points: 3,351, Level: 1 Points: 3,351, Level: 1
brighthorizon's Avatar
Car: 2007 Chrysler 300 Touring Signature Series
Member Number: 9510
You probably have to get your fenders rolled???
My Mods
  • Tortoise Shell Shifter, Door Pulls, Steering Wheel, Dashkit, Garage Opener, Ventguards, Fender Trim, Vanity Plates
  • Silverstar Ultra 9005 & 9006, Angel Eyes, Tints 50% Front, 20% Rears
  • Stinger battery, MTX Thunder 9500 Subs, Phoenix Gold Octane Amps w/neons, Power Acoustik Cap, Headrest DVD monitors
  • Blastin Bob duals, Tinted Tails, LSD Lambo Doors, remote start, AF Nav in motion hack
  • 20" Luff D2 Staggered 255/45 front, 285/40 rear
brighthorizon is offline
Old 12-24-2007, 01:58 AM   #3 (permalink)
Points: 938, Level: 1 Points: 938, Level: 1 Points: 938, Level: 1
Car: 2007 chrysler 300 touring
Member Number: 15841
rolling fenders can be simple you just have to do it slow. all you need is a baseball bat. stick the handle end in the fender against the tire. tilt the handle up until it touches the fenders lip. then add a bit more pressure and roll the bat. applying more pressure against the lip as needed.
done it a million times and it worked every time!
//...NEGATIVE CAMBER WORLDS LOWEST...\\
//NC\\ HUSKY is offline
Old 12-24-2007, 11:32 AM   #4 (permalink)
Points: 16,824, Level: 1 Points: 16,824, Level: 1 Points: 16,824, Level: 1
CUEBALL's Avatar
Member Number: 3447
Roll the fender.... but only use the bat method if you've done it a million times..LOL
Go have a shop do it with a fender roller, and heat gun to soften the paint. You'll wonder why you didn't have it done already!!
CUEBALL is offline
Old 12-24-2007, 12:34 PM   #5 (permalink)
chunk77's Avatar
Car: 2006 C 300
Member Number: 4164
I may call that shop in Austin you told me about
chunk77 is offline
Old 12-24-2007, 02:03 PM   #6 (permalink)
Points: 13,425, Level: 1 Points: 13,425, Level: 1 Points: 13,425, Level: 1
taylormotorsports's Avatar
Member Number: 3502
Rolling the fender should take care of it. As for the "grease" you have on the inside of your fenders, that's probably just fly-away (excess tire dressing) that's flung when your tires are spinning. I've got lots of it myself...
TMS
2006 Silver steel metallic, 300C, 22" 2-piece Sequence SQ6 wheels, LSD lambo doors, GT Factory rear lambos, Grip brushed aluminum top (polished), AFE 2 intake, Grip chrome grill , Eibach Pro kit, SRT8 rear spoiler, DVD/screens, chrome dash kit, 20% tint, LED tails, Blastin' Bobs exhaust, Escalade fender vents, BT everything!, Stealth pedals, stainless braided hose covers.
WARNING! DO NOT do business with Nocturnal Imports! PM me for details. WARNING!
taylormotorsports is offline
Old 12-25-2007, 01:19 AM   #7 (permalink)
yeah i agree with you. ive done it to more vehicles than i can remember mine and my friends. i also use a heat gun.. i guess i forgot to mention that..
Old 12-25-2007, 09:02 AM   #8 (permalink)
CUEBALL's Avatar
Member Number: 3447
Originally Posted by chunk77 View Post
I may call that shop in austin you told me about
Good deal! Hope you get your issues sorted!
CUEBALL is offline
Old 12-31-2007, 01:44 PM   #9 (permalink)
Points: 2,408, Level: 1 Points: 2,408, Level: 1 Points: 2,408, Level: 1
JusticePete's Avatar
Car: 2005 Chrysler Pacifica
Member Number: 10746
Tires when rubbed hard enough get greasy. Think of the little grease balls you create when you do a good burn-out. I use the greasy spots when ever I check a car for fender rub. Wash all the tire shine off your tires and out of the fender wells. Use a degreaser to get the old tire grease off too. Drive your car until you get the rub. Pull your fingers straight out from the fender well in steps and note where the grease marks are. You'll know exactly where the tire is rubbing on your fender. The body shop that does the rolling will know too. Before you square up with the body shop on your rolling bill take a test drive with the car full of people. If it needs more rolling while you are at the shop would be a good time.
Pete Basica
www.PeddersUSA.com
JusticePete is offline
Old 12-31-2007, 02:48 PM   #10 (permalink)
Points: 3,078, Level: 1 Points: 3,078, Level: 1 Points: 3,078, Level: 1
tx_bandit's Avatar
Car: 2006 Chrsyler 300C SRT8
Member Number: 15722
Sorry, off topic, but can I ask where you got your exhaust?
Thanks!
tx_bandit is online now
