Old 02-13-2008, 05:23 PM   #11 (permalink)
Points: 158,514, Level: 1 Points: 158,514, Level: 1 Points: 158,514, Level: 1
Member Number: 232
Originally Posted by djh035 View Post
Let us know how you make out. I have the same screnching(if that's a word) noise when i go over bumps or pull out of my driveway. Sounds like I'm in need of a Lube job.
I can't think of anything to lube but the sway bars. I think everything else is sealed for life, or until replacement.
joey is offline
Old 02-13-2008, 05:27 PM   #12 (permalink)
Points: 2,546, Level: 1 Points: 2,546, Level: 1 Points: 2,546, Level: 1
COPPERSHOT's Avatar
Car: 2005 CHRYSLER 300 LIMITED
Member Number: 5170
Send a message via AIM to COPPERSHOT
My Noise Is All The Time...not In The Brakes...but However I Did Have The Rattle In The Brakes As Well...all It Is , Is The Pad Is Moving Aroung When You Hit A Bump...i Put New Pads In And It Was Corrected...sounds Like A High Pitch Tinny Rattle...i Think You Can Bend The Tabs As Well To Correct It...mine Is Definitely Suspension...
"GET IT STRAIGHT BUSTER....IM NOT HERE TO SAY PLEASE....IM HERE TO TELL YOU WHAT TO DO....IF SELF PRESERVATION IS AN INSTINCT YOU POSSES YOU BETTER F#$%^N DO IT!...AND DO IT QUICK!... IM HERE TO HELP...IF MY HELP IS NOT APPRECIATED...LOTS OF LUCK GENTLEMAN." (WINSTON WOLF)
COPPERSHOT is offline
Old 02-14-2008, 10:57 PM   #13 (permalink)
Points: 1,612, Level: 1 Points: 1,612, Level: 1 Points: 1,612, Level: 1
253motoring's Avatar
Car: 2006 chrysler 300 SRT
Member Number: 14825
I tried the brakes over bumps and it is still there it really sounds like the struts are bottoming out or something is lose! Any more ideas???
253motoring is offline
Old 02-18-2008, 03:24 PM   #14 (permalink)
Points: 5,731, Level: 1 Points: 5,731, Level: 1 Points: 5,731, Level: 1
Car: 2006 Chrysler 300 LX
Member Number: 14521
well i fixed my problem. All i did was take off the brakes and remove the anti rattle clips bend them a little more to sit better on the brakes and as of right now NO NOISE!!! YES!!! it really sounded like something was broken under my car and on bumps moving around and rattling.
Dove dkla is offline
Old 02-19-2008, 10:09 AM   #15 (permalink)
Points: 603, Level: 1 Points: 603, Level: 1 Points: 603, Level: 1
Car: 2006 Chrysler 300 SRT8
Member Number: 16630
Mallard
Originally Posted by 253motoring View Post
When we drive the car the strut sounds like it is lose or bouncing alittle makes a wierd noise anyone else have this problem we only have 21K on the car cant need to replaced yet!
If this happend or is happening to you give me your thoughts
Mallard is offline
Old 02-19-2008, 10:13 AM   #16 (permalink)
Mallard
I have the same problem. Someone had posted about changing the struts but to my knowledge never said if it fixed the problem. It is my guess that the struts need to be other than Mopar. Any thoughts?
Mallard is offline
Old 02-26-2008, 10:20 AM   #17 (permalink)
Anyone out there?
Sure wish someone would have an answer.
quote=Mallard;649583]I have the same problem. Someone had posted about changing the struts but to my knowledge never said if it fixed the problem. It is my guess that the struts need to be other than Mopar. Any thoughts?[/
Mallard is offline
Old 02-26-2008, 10:31 AM   #18 (permalink)
Points: 1,851, Level: 1 Points: 1,851, Level: 1 Points: 1,851, Level: 1
billiardbrawler's Avatar
Car: 2006 300C srt8
Member Number: 11358
I only have 2,200 miles and have the same noise. Sounds like the struts are loose. I had heard that guys that replaced their struts took care of the problem.
Incidently, I purchased a new Charger sxt ' 3 weeks ago and it is solid as a rock up front....it'll be interesting how the dealer handles it...
If you seek happiness for yourself...you'll never find it...when you seek it for others...you'll find it yourself
06' 300 SRT8
07' Charger SXT 3.5
05' Mustang GT
93' 300 RWH Supercharged Miata
08' 6.4 Power Smoke (650 lbs of torque)
00' Dodge Ram 1500 Conversion
billiardbrawler is offline
Old 03-07-2008, 08:21 AM   #19 (permalink)
Points: 2,131, Level: 1 Points: 2,131, Level: 1 Points: 2,131, Level: 1
Car: 300 C 2005 CHRYSLER
Member Number: 5739
Im having the same problem with mine, car drives fine and handles fine for the most part, but when i hit small bumps, potholes etc. I get this rattling sound like all of you that sounds like the struts are loose or the mounts are bad. I planned on replacing the struts and the mounts.
Has anyone had a clear solution yet?
How much can you get struts and mounts for? I heard KYB offers them now? Any idea on price ? Do I have to order direct from KYB?
V8KILLR4U is offline
Old 03-08-2008, 07:59 PM   #20 (permalink)
Anyone try replacing the struts??? I am dropping this at the dealer this week so they can look at it!
