View Poll Results: If you had outer tie rod failure, what is your rim size?
Stock 51 62.96%
20" 14 17.28%
20" Forged 1 1.23%
22" 12 14.81%
22" Forged 1 1.23%
Other 2 2.47%
Voters: 81. You may not vote on this poll
Old 09-09-2008, 06:57 PM   #21 (permalink)
Points: 5,097, Level: 1 Points: 5,097, Level: 1 Points: 5,097, Level: 1
kmoney's Avatar
Member Number: 926
Originally Posted by LSCto300C View Post
My suspension thuds over some bumps a lot louder than I think it should. I asked my dealer about it and they said that there was nothing they could do unless there was a total failure because they said they had to send it to chrysler. So am I being told that they want my front tires to completely go pizza (think of skiing) before they'll do anything?? Is this BS?
1 Jack the front of the car up and shake the wheel via tire left and right, if it has play. the tierods are bad..
2 find a new dealership. Dont risk your life waiting on them to come apart. If there is play THEY ARE BAD!! Call Chrysler Customer service if they wont replace them.. Be Nice but firm..
kmoney is offline
Old 09-09-2008, 09:49 PM   #22 (permalink)
Points: 8,937, Level: 1 Points: 8,937, Level: 1 Points: 8,937, Level: 1
LSCto300C's Avatar
Car: 2007 Chrysler 300C in Steel Blue
Member Number: 16416
Trader Rating: (6)
Thanks for the info kmoney. I'll try the wiggle test and also start going to our other dealer.
"Obama could achieve world peace and all the republicans
would do is bitch about how he undermined
the defense sector" -aedison
Startech Grille imported by elite300
yamabob Illuminated Wing
SRT headers/mids
Econo heads/ Sidewinder cam
LSCto300C is offline
Old 09-10-2008, 12:43 AM   #23 (permalink)
Points: 158,803, Level: 1 Points: 158,803, Level: 1 Points: 158,803, Level: 1
Member Number: 232
My front wheels had a lot of play and knocking sound when I held the wheel in the 3 and 9 O'Clock position. You can see it these vids.
YouTube - Chrysler 300c bad tie rods?
YouTube - Chrysler 300c clunking noise
My first thought was bad tie rods because the wheels exhibited the symptoms often described for bad tie rods. However I never had any other symptoms like popping noises, wheel vibrations at high speeds, or road wander that are other symptoms of bad tie rods. The alignment shop also said my tie rods were OK. Apparently during an alignment bad outer ties rods are real obvious because the alignment specs will keep changing and it is hard to set the toe.
Later I found my tension strut bushings were torn and the dealer replaced them. After the tension struts were replaced my wheel wiggle/knocking sound was significantly reduced.
So be carefully jumping to conclusions that wheel play are bad tie rods.
joey is offline
Old 10-08-2008, 06:48 PM   #24 (permalink)
Points: 4,470, Level: 1 Points: 4,470, Level: 1 Points: 4,470, Level: 1
300C-hris's Avatar
Member Number: 6245
Send a message via AIM to 300C-hris
I just dropped my C about a week ago... I installed Pedders bump steer bushing kit and went for an alignment today... The tech told me MY inner tie rods were shot.... Is this covered under warrenty???I got the car used but I did buy an extended warrenty for up to 75,000 miles it has 55xxx miles now! Any body know if it would cover this? Also if not where can I get some new iner tie rods?? Thanks
300C-hris
300C-hris is offline
Old 10-08-2008, 07:26 PM   #25 (permalink)
Member Number: 232
If you have a Chrysler Maximum Care extended warranty than the inner tie rods are covered under warranty.
If you have any other extended warranty, then you need to read the contract.
joey is offline
Old 10-09-2008, 12:42 AM   #26 (permalink)
300C-hris's Avatar
Member Number: 6245
Its a Comprehensive coverage up to 75000 miles... The tie rods are listed under suspension coverage but I'm afraid what they will tell me........
Old 10-09-2008, 01:44 AM   #27 (permalink)
300C-hris's Avatar
Member Number: 6245
Will lowering my car void such a warrenty? Or any warrenty?? There not 'mopar' parts so I'm nervous....also any vendors where I can get these inner tie rods for both sides of the vehicle? Thanks guys....
Old 10-09-2008, 08:34 AM   #28 (permalink)
Points: 5,200, Level: 1 Points: 5,200, Level: 1 Points: 5,200, Level: 1
Member Number: 14270
well even using a mopar cai can void your warrenty
Stainless Steel Mesh Grill [X]
SRT8 spoiler [X]
Lower bumper mesh [X]
Clock Mod [X]
Painted to match Engine Cover [X]
Pedders suspension parts [X]
AAC Halos 6000K - to be installed, unless sold
bund is offline
Old 10-09-2008, 11:14 AM   #29 (permalink)
300C-hris's Avatar
Member Number: 6245
What about lowering the car does that Void any warrenty?
Old 10-09-2008, 03:47 PM   #30 (permalink)
300C-hris's Avatar
Member Number: 6245
Any one possibly??? Thanks. !
