View Poll Results: If you had outer tie rod failure, what is your rim size?
Stock 48 62.34%
20" 14 18.18%
20" Forged 1 1.30%
22" 11 14.29%
22" Forged 1 1.30%
Other 2 2.60%
Voters: 77. You may not vote on this poll
Old 07-31-2008, 12:39 AM   #1 (permalink)
Member Number: 232
Outer Tie Rod Failure - What rim size are you running?
For those that have replaced outer tie rods, what rim size are you running?
The purpose of this poll is to see if heavier rims/wheels might be causing the failures.
joey is offline
Old 07-31-2008, 02:43 AM   #2 (permalink)
Points: 10,198, Level: 1 Points: 10,198, Level: 1 Points: 10,198, Level: 1
UK CHRYSLER 300C's Avatar
Member Number: 12398
20" startechs,I've both outer tie rods replaced and 2 steering racks replaced,so far
UK CHRYSLER 300C is offline
Old 07-31-2008, 04:07 AM   #3 (permalink)
Points: 2,814, Level: 1 Points: 2,814, Level: 1 Points: 2,814, Level: 1
Mr.C's Avatar
Car: 2005 All Options 300C
Member Number: 3017
I have a 05 300c with 20k miles on it and I am running the stock wheels, I am now on my second set of outter tie rods only this second set is made by moog and I am hoping they last longer than OEM.
Mr.C is offline
Old 09-01-2008, 03:33 PM   #4 (permalink)
Member Number: 232
From the 7 responses so far, all the failures except 1 was on the stock wheels.
Keep the votes coming if you had a outer tie rod failure.
joey is offline
Old 09-01-2008, 03:53 PM   #5 (permalink)
Points: 26,291, Level: 1 Points: 26,291, Level: 1 Points: 26,291, Level: 1
bruno's Avatar
Member Number: 3129
I'll bet the results so far are surprising you, joey, considering you have thought the failures to be caused by larger and/or heavier rims. We shall see since this poll was a good idea to post up.
So far, I don't have any issues that I know of on my 20" rims at 3.5 years of age.
bruno is offline
Old 09-01-2008, 04:06 PM   #6 (permalink)
Member Number: 232
You are absolutely right Bruno. The results are surprising. Especially considering how many folks on this forum have 20's/22's. Probably more than the normal population. With 7 failures out of 135 views, it would appear the failure rate may not be as bad as thought.
joey is offline
Old 09-01-2008, 04:14 PM   #7 (permalink)
Points: 5,161, Level: 1 Points: 5,161, Level: 1 Points: 5,161, Level: 1
duke_dallas's Avatar
Member Number: 5928
Outer tie rod? Is that the same thing as the stabilizer bar which I think connects to the sway bar? I had this replaced recently but don't what to vote if it's different.
Wheels & Tires - 24x9.5 Verde's, 255/30 Kumho's
Exterior - Dub Edition grille, E&G lower mesh, 25% tint, tinted tails, painted side markers, LED Halos, LED fogs
Interior - Visor Disguisors, padded console (22 Elite), Ultimate Pedals, LED bulbs
Performance - K&N drop-in, Superchips, Pedders bushings
Convenience - Nav Hack, iPac iPod input
http://www.cardomain.com/ride/2615386/1
duke_dallas is offline
Old 09-01-2008, 04:36 PM   #8 (permalink)
Member Number: 232
I should have included a pic in my original post.
If the dealer replaced the outer tie rod under warranty you probably never saw the part. Dealers don't usually give you the bad parts that are replaced under warranty.
Here are two views.
outer-tie-rod-failure-what-rim-size-you-running-tension-strut3.jpg   outer-tie-rod-failure-what-rim-size-you-running-outer-inner-tie-rod.jpg
joey is offline
Old 09-01-2008, 07:52 PM   #9 (permalink)
Member Number: 5928
Great pics. It was the sway bar end link that broke on mine.
Old 09-01-2008, 09:19 PM   #10 (permalink)
Points: 12,931, Level: 1 Points: 12,931, Level: 1 Points: 12,931, Level: 1
crhemi's Avatar
Car: 2006 Chrysler 300C SRT
Member Number: 3307
Trader Rating: (4)
I've not heard of any SRT's having this issue. I did on my 5.7 at 30K miles.
crhemi is offline
