Old 08-20-2008, 07:11 PM   #21 (permalink)
GROUNDED's Avatar
Member Number: 10038
Originally Posted by UniversalAirSuspension View Post
The Koni shocks that we carry is a Custom made unit that Koni has produced for us, for the LX Platform. They are carry the full Koni Warranty.
If your worried about the warranty aspect of it you can email Jim Ryan at Koni, His email address is Jim.Ryan3@itt.com
and those shocks are worth every penny and some. Trust a brotha!
GROUNDED is offline
Old 08-22-2008, 02:19 PM   #22 (permalink)
Points: 5,286, Level: 1 Points: 5,286, Level: 1 Points: 5,286, Level: 1
Member Number: 5047
Originally Posted by nazab View Post
I have 300C 5.7L , don't like the soft ride and floaty up and down body movement over the large bumps in high speeds , but I don't want to lower the car .. so the right thing to do is I guess to change OE shocks by stiffer /more sporty ones. The choices I found from reading all the threads in the forum are the following :
1) Change the OE shocks by SRT8 OE shocks ... technicaly it is ok and makes sense .. but has anyone tried it ? does it really help ?
2) Change the OE shocks by KW sports dampers ( Not KW1 or KW2 ) , just sports dampers with the original car springs ... again has anyone tried this ?
3) Found Koni shock absorbers offered through only one vendor and not even mentioned in Koni's website or through any other supplier or source !! These are more expensive .. but I have worries to buy a product that even the producer denies that it produces it ! What will happen if doesn't actually fit the car or if anything goes wrong with any of these shocks ? what kind of warranty or guarantee would one expect ? Has anyone tried them with the original springs of the car ?
Your advise on any of the above would be highly appreciated guys ...
Check on Koni's website, it has been updated http://www.koni-na.com/index.cfm
-Zack Ratcliff
800-864-2470
Old 08-22-2008, 02:32 PM   #23 (permalink)
Points: 1,704, Level: 1 Points: 1,704, Level: 1 Points: 1,704, Level: 1
Car: 2006 Dodge Charger SRT8
Member Number: 17780
So you mean changing shocks while keeping the original springs will not solve the problem as the original springs and shocks are too soft !! So which springs/shocks are available that are stiffer and will not lower the car ?
These springs will lower the car about 10mm from stock, which isn't a lot. But they will increase the rate of the rear springs. The ride height of the various LX platforms varies, so if you wanted to measure your height compared to where you'd be with ours there is a how to on the spring page.
These are the Pedders GSR shocks that have much better valving than the OE parts do, they are non adjustable by knobs, but have auto adjusting valving to adjust themselves to road conditions.
Rob@WretchedMS is offline
