Originally Posted by JKOD
 Hey all.. Got a 300c Hemi 5.7 and having such a bum ride after placing fusion 20 inch wheels and toyo proses S/T 255 45/20's on the car. Already replaced the right control arm and linkage and new struts.. Ride is smooth as hell on the highway but look out when hitting bumpy pavement. Feels like the tires are gonna go thru the well and the hard bangs are making me absolutely nuts. What in the name of God is it? Rims? Tires? Tie rods? Stabilizer Bar? ANY SUGGESTIONS would be so welcomed !! Thanx PS I'm Bill
Lots of noise issues with the LX front end. Did it occur before you did all the work?
Areas of concerns are
1. Top strut mount bushes
2. End links
3. Tie rods
4. Loose ball joint nuts. (you said you already replaced a control arm). The ball joint nuts are challenging sometimes to get tight.
5. sway bar mounting bushings
6. Torn radius rod and/or lower control arm bushings
7. torn upper control arm bushings
These are all areas that I have seen that can create really loud noises, and not just tinny kinds of rattles.
So again, when did the noise start specifically
mike
dms
