Old 10-25-2008, 09:06 AM   #1 (permalink)
Points: 4,476, Level: 1 Points: 4,476, Level: 1 Points: 4,476, Level: 1
kmoney's Avatar
Member Number: 926
Ride height uneven
I have a 2005 300 Touring on 22's I had the car sitting in the garage and as I was walking up towards the rear of the car I noticed that the car appeared to be leaning to the right. The fisrt thing I did was check air pressure. All was the same. Then I placed my hand between the tire and fender and noticed that I could put my habd on top of the tire without touching the fender on the left but I cant on the right. All of the suspension is stock. I have replaced the inner and outer tierods and the torque struts since ive owned the car. Just wondering if anyone has noticed this on there car.
I put a tape measure up to the car acroos this center cap of wheels to the bottom of the fender heres what I got.
LF 30 3/4
RF 301/4
LR 31
RR 30 1/2
kmoney is offline
Old 10-26-2008, 12:17 PM   #2 (permalink)
Points: 6,055, Level: 1 Points: 6,055, Level: 1 Points: 6,055, Level: 1
Inferno07's Avatar
Car: 2007 Chrysler 300C
Member Number: 16364
Send a message via ICQ to Inferno07 Send a message via AIM to Inferno07 Send a message via Yahoo to Inferno07
Your garage floor probably leans inward for drainage. Might want to repeat these measurements in a good flat parking lot and see what you come up with.
Brett DiMichele
2007 Inferno Red 300C
HIDGate 6000K HID Low Beam and Driving Lights [X]
AAC Red/White Bling Rings [X]
AAC Oracle Red Interior LED's [X]
Grillcraft MX Grill [X]
IPCW LED Tails [X]
Revelations S.S. Pillar Post Trim [X]
CDC Tech Trunk Filler Panel [X]
Inferno07 is offline
Old 10-26-2008, 08:56 PM   #3 (permalink)
kmoney's Avatar
Member Number: 926
Nope no drain in the garage. Car is leaning I took it up to a local shop just to make sure it wasn't something serious, Taking to the dealer when I get back from business trip
kmoney is offline
Old 10-26-2008, 10:11 PM   #4 (permalink)
Points: 19,771, Level: 1 Points: 19,771, Level: 1 Points: 19,771, Level: 1
Scarbs's Avatar
Car: 2005 Chrysler 300C Deep Lava Red 1 of 1641
Member Number: 446
Have someone sit in the driver seat and then measure it again. My 05 C is like that but thats how they were, the engine is set to one side old school style. They moved it a little more center in 06 and then 07. At least thats how the Cs are. I took out a 1/4in out of the LF with the KW suspension but i did leave a little for driver weight.
It could also be the body panels. A week after i got the car I noticed it was lop sided meaning the panels on the right weren't aligned with the left. You didn't notice it till you looked at the car from the front. The dealer had to adjust fenders and doors on the left to get all the lines to match. I should have taken pics back then but i wanted it fixed.NOW
Eric
Black Cherri 1 of 1641
Bad Monkey
Scarbs is offline
Old 12-01-2008, 10:38 PM   #5 (permalink)
Points: 1,418, Level: 1 Points: 1,418, Level: 1 Points: 1,418, Level: 1
dredog95's Avatar
Car: 06 dodge charger/daytona/gomango
Member Number: 10990
Pm sent but your box is full.
dredog95 is offline
