Old 10-25-2008, 10:09 AM   #1 (permalink)
Points: 5,200, Level: 1 Points: 5,200, Level: 1 Points: 5,200, Level: 1
Member Number: 14270
Tie rods
Hey guys, I was wondering how you can tell if its your inner or outer tie rod that needs replacing?
Stainless Steel Mesh Grill [X]
SRT8 spoiler [X]
Lower bumper mesh [X]
Clock Mod [X]
Painted to match Engine Cover [X]
Pedders suspension parts [X]
AAC Halos 6000K - to be installed, unless sold
bund is offline
Old 10-26-2008, 02:18 PM   #2 (permalink)
Points: 1,704, Level: 1 Points: 1,704, Level: 1 Points: 1,704, Level: 1
Car: 2006 Dodge Charger SRT8
Member Number: 17780
Grab the tire at 3 and 9 with it jacked up, and shake it back and forth, (best to have someone do this for you, and look and feel the socket for the tie rod,
Typically you can see the outer, but sometimes you can't
Inners you can't really see, you have to stick your thumb in to the bellows boot and feel for the end of the rod where it goes in to the socket. see if you have play with the tire being 'wiggled'
Rob@WretchedMS is offline
Old 10-26-2008, 04:33 PM   #3 (permalink)
Member Number: 232
Here is the info I learned from my alignment shop.
Outer tie rods - When getting your front end aligned, the toe settings will keep moving/changing if you have bad outer tie rods. It is difficult to do a proper toe alignment with bad tie rods.
Inner tie rods - With front end on jacks, have another person hold the wheel in the 3 & 9 O'Clock position and jiggle each wheel.
While the wheel is being jiggled, you should grab the inner tie rod and feel for metal banging/clunking coming from inside the bellows. It is very obvious if there is any clunking from the inner tie rods.
joey is online now
Old 10-27-2008, 05:33 PM   #4 (permalink)
Points: 6,055, Level: 1 Points: 6,055, Level: 1 Points: 6,055, Level: 1
Inferno07's Avatar
Car: 2007 Chrysler 300C
Member Number: 16364
Send a message via ICQ to Inferno07 Send a message via AIM to Inferno07 Send a message via Yahoo to Inferno07
I just did outer tierods on my co-workers wife's 01 Caravan this weekend.. When he went to get it lined up the toe would change as they made adjustments. They quoted him $150.00 per side... $86.00 for two of the best MOOG outers and 45 minutes of my time and they were el-done-O... Took it back to get it lined up and I was off less than half a degree
I have never changed inners but just about every mopar made in this decade has ball joint and outer tie rod issues!
Brett DiMichele
2007 Inferno Red 300C
HIDGate 6000K HID Low Beam and Driving Lights [X]
AAC Red/White Bling Rings [X]
AAC Oracle Red Interior LED's [X]
Grillcraft MX Grill [X]
IPCW LED Tails [X]
Revelations S.S. Pillar Post Trim [X]
CDC Tech Trunk Filler Panel [X]
Inferno07 is offline
