Old 10-29-2008, 03:59 PM   #1 (permalink)
Points: 2,504, Level: 1 Points: 2,504, Level: 1 Points: 2,504, Level: 1
f4aar's Avatar
Car: 2006 Chrysler 300C SRT-8
Member Number: 3693
alignment specs 300 srt8
I had my alingment done today, after ajustments all specs were on target execept for the caster it was slightly over the max it was 12.30.the tech said it would be fine and would not afect tire wear .He said he could adjust the cradle for a extra charge.How important is caster adjustment.
thanks for any input
f4aar is offline
Old 11-06-2008, 06:58 PM   #2 (permalink)
Points: 947, Level: 1 Points: 947, Level: 1 Points: 947, Level: 1
Member Number: 18368
As a tech I figured I should reply. Caster is mostly a stability angle and usually not adjustable from the factory. Hence the cradle adjustment. Caster is most felt when straight line stability is needed, a car with out of spec caster could wander or in extreme cases cause a pull but will not wear tires. So long as the car drives straight and true, and all the other angles are right on, I wouldn't worry about Caster unless it is out by a great amount.
Hope that helped.
--Justin
-2000 Dakota R/T Bolt on's and a built trans
13.5@102 Motor 12.2@110 150 Shot
-1995 Honda Civic Built 1.6 Single Cam on 15PSI 13.6@111
-2006 300C SRT8 Diablo, 275 Vreds, 176 t-stat, and Magnaflow High-flow cats
12.3@113
SilverSRTSedan is offline
Old 11-07-2008, 06:45 AM   #3 (permalink)
Points: 1,704, Level: 1 Points: 1,704, Level: 1 Points: 1,704, Level: 1
Car: 2006 Dodge Charger SRT8
Member Number: 17780
Caster is not adjustable unless you have upgraded to adjustable upper control arm bushings, and as Justin stated it's not a big deal. As long as the difference left to right is close you have nothing to worry about.
Higher caster numbers will give you more road feel, quicker wheel return, and better turn in
Rob@WretchedMS is offline
Old 11-10-2008, 11:18 AM   #4 (permalink)
f4aar's Avatar
Member Number: 3693
thanks for the information guys , hope everyone has a grate Veterans Day.
f4aar is offline
Old 11-16-2008, 10:40 PM   #5 (permalink)
dms
Points: 3,166, Level: 1 Points: 3,166, Level: 1 Points: 3,166, Level: 1
dms's Avatar
Car: 2006 Pontiac G/P
Member Number: 16007
Having a slightly higher caster is a good thing. I would not have any concerns about it.
mike
dms
A
Michael White
Pedders West Coast Manager
mike.white@PeddersUSA.com
925-215-1308
Videos of Stock OEM bushes
dms is offline
