Old 10-30-2008, 12:59 PM   #1 (permalink)
Points: 375, Level: 1 Points: 375, Level: 1 Points: 375, Level: 1
Car: 2006 chrysler 300c
Member Number: 19779
front end noise
had a cluncking in the front end so i took it to the dealership and told them, they said they herd it and wanted me to come back.
so i went back and there working on it. i gave it to them at 1:30 yesterday and they said they have to keep it overnight so im kinda scared it's more then the tie-rod's. any help?
indiana300c is offline
Old 10-30-2008, 07:14 PM   #2 (permalink)
Points: 4,699, Level: 1 Points: 4,699, Level: 1 Points: 4,699, Level: 1
Car: 2008 Chrysler 300C
Member Number: 3268
On mine they put sway bar bushings, and then tie rods did the trick.
Buz-CCC is offline
Old 10-30-2008, 10:44 PM   #3 (permalink)
Member Number: 232
Unfortunately the front suspension and steering system is the Achilles heal of this car. I get the impression you do not have an extended warranty. If you did, most repairs would be covered under the extended warranty. If the repairs are on your dime you want to hope they find and fix the problem on the first attempt and they don't get into the replace each component until they find the problem through the process of elimination.
Let us know what they find when you get your car back.
Here are some pics of the front suspension and steering. This might help when they start talking shop.
front-end-noise-upper-control-arm.jpg   front-end-noise-tension-strut3.jpg   front-end-noise-lower-control-arm-sway-bar.jpg   front-end-noise-tension-strut-ball-joint.jpg   front-end-noise-steering-gear.jpg
joey is online now
Old 11-01-2008, 04:09 PM   #4 (permalink)
Points: 10,847, Level: 1 Points: 10,847, Level: 1 Points: 10,847, Level: 1
wog boy's Avatar
Car: 2006 . 300c, rolling on 24's
Member Number: 5242
Let us know what they find when you get your car back.Here are some pics of the front suspension and steering. This might help when they start talking shop.
Well done with the pics mate, I'm sure alot of people will find this information helpfull
**My Youtube Video**
wog boy is online now
Old 11-05-2008, 04:04 PM   #5 (permalink)
yea it's under warenty i only have14,000 miles on it and its 2 years old
and whatever they did worked because the noise is gone and the ride is stiffer
Old 11-05-2008, 06:58 PM   #6 (permalink)
Points: 7,329, Level: 1 Points: 7,329, Level: 1 Points: 7,329, Level: 1
Member Number: 1483
What do you mean "whatever they did"?
You could at least ask them exactly what they did and report the details here for the benefit of all.
DESIREE is offline
Old 11-05-2008, 07:05 PM   #7 (permalink)
im going to read all the paper's before i go to bed and will explaine in detail tomorow
Old 11-15-2008, 01:10 PM   #8 (permalink)
Points: 603, Level: 1 Points: 603, Level: 1 Points: 603, Level: 1
Member Number: 16665
well i don't have an extended warranty and my issue was the left side outer tire rod per the dealer' but I still here some noise not as much but it,s still their...dealer said the tire rod was loose which made the popping sound..so i will keep you posted when I take my car back....2006 300C
Bluedog is offline
