Old 11-12-2008, 10:50 AM   #1 (permalink)
Points: 1,038, Level: 1 Points: 1,038, Level: 1 Points: 1,038, Level: 1
Car: 2007 chrysler 300c srt8
Member Number: 19724
Tucking 24's on air as much as possible.
Ok i got 24's on my 300c and i want to bag it. Now i really wanna tuck my 24's upfront. I know all air ride kits will but i want to go a bit lower. Is there on air ride kit that you notice sits lower then another? also what stops the front end from going down lower? i got no problem cutting out the inner fenders on the front of my car. Any members really low and tucking 24's? pics?
1nice300c is offline
Old 11-13-2008, 12:19 PM   #2 (permalink)
Member Number: 5047
24's No Cuttings
24's no cutting with Koni adjustable struts
22's no cutting with koni adjustable struts
To lay out on the 24's they are cutting out for the upper control arm to go through the strut tower, Raising the inner wells to clear out for the 24's.
-Zack Ratcliff
800-864-2470
Old 11-13-2008, 06:14 PM   #3 (permalink)
awesome post and thanks for that. This is the reason i will be ordering from you guys next month when its time to do my air set up.
Old 06-03-2009, 12:16 AM   #4 (permalink)
3**
Points: 16, Level: 1 Points: 16, Level: 1 Points: 16, Level: 1
Car: 2006 chrysler touring
Member Number: 22542
any one have any photos
wut needs to be cut to achieve this drop any pics of inside the fender and on top in the fenders......
3** is offline
Old 06-04-2009, 11:52 AM   #5 (permalink)
Member Number: 5047
No, I don't have any pictures, Some people are just folding over the ridge that is under the inner fender wells, but, to get it to really drop down, you need to cut out for the upper arm, and then cut above the tires and raise that portion up. Usually you will just cut little by little until you get the clearance that your after.....
Old 06-04-2009, 03:14 PM   #6 (permalink)
Points: 13,031, Level: 1 Points: 13,031, Level: 1 Points: 13,031, Level: 1
Flossin22s's Avatar
Car: 2006 chrysler 300
Member Number: 2931
you that to make room for the tires and top part of the control arm to move higher into the engine compartment.
this car tubbed the fenders but not the top part for the control arm.
tubbed for the tires
this is another car, this is what u want to cut for the control arm to go up.
Flossin22s is offline
Old 06-04-2009, 03:15 PM   #7 (permalink)
Flossin22s's Avatar
Member Number: 2931
make sure to save the pics because im gonna delete them from my photobucket soon. If u want them that is.
Old 06-04-2009, 07:37 PM   #8 (permalink)
3**
Those Cars Are On Hydros Right Or On Air I Have 24" Dropstars And Im On Air Maybe Thinking On Moving On To 26 And I Really Love That Tuck Those Picks Helped Thanks Wondering If Anyone Has Pics Of The In Side Of The Fender And Does The Anything Have To Be Reinforced
3** is offline
Old 06-04-2009, 08:08 PM   #9 (permalink)
GROUNDED's Avatar
Member Number: 10038
Everything cut should be tubbed with sheetmetal that is welded in. Anything is possible with beer and sawzalls.
GROUNDED is offline
Old 06-04-2009, 10:05 PM   #10 (permalink)
3**
Cut And Ask ? Later..lol
Its Just Wanna See Every Thing People Did So I Can Know Wut To Do Im A Visible Kind Of Guy So It Should Be Welded
I Was Thinking Cut Then Fiberglass So I Can Get That Factory Look So Sheet Metal
3** is offline
