Old 11-15-2008, 02:03 PM   #1 (permalink)
Points: 1,704, Level: 1 Points: 1,704, Level: 1 Points: 1,704, Level: 1
Car: 2006 Dodge Charger SRT8
Member Number: 17780
Stock LX Radius Rod Bushing Video 11/15/08
These videos i took with my camera when we had a Magnum in the shop, The first video is with the car on the alignment rack, and as i'm videoing the right front Radius Rod Bushing from under the car, I have my tech turning the wheel back and forth.
You can see in the video the Radius Rod bushing are just pulling apart, I would like to get everyone a video of them under heavy braking, but it will cost a good amount of money to have a setup capable of doing this reliably.
Raw Video,
YouTube - 2005 Magnum Radius Rod Bushing - Bad
This next video is taken with the car lifted up in the air on a twin post lift, and the wheels off. I then have my tech move the wheels left to right while i film it.
This is video of the left front Radius Rod Bushing taken from the left front wheel well.
Raw Video
Many of you have remarked that one of our previous videos wasn't accurate because the movement was not in the correct direction. The videos that i've taken here will show you that it actually was pertinent to the LX driving conditions, as it moves very similar,
Previous Video
YouTube - Chrysler LX Radius Rod Bushes and Why they Fail
Rob@WretchedMS is offline
Old 11-15-2008, 04:27 PM   #2 (permalink)
Member Number: 232
Those are great videos. My tension strut bushings looked similar before they were replaced.
What is the best way to see if the other bushings are bad, such as the upper and lower control arm, without taking the part off the car?
The tension strut is easy to see.
Also, what about the rear bushings?
The attached pics are my rear camber links, which look bad. I also have some creaking noises from the left rear, as shown in this video.
YouTube - Chrysler 300C Creaking Rear Suspension
Maybe a better question - How does Pedders inspect all the bushings?
stock-lx-radius-rod-bushing-video-11-15-08-camber-link-bushing-closeup.jpg   stock-lx-radius-rod-bushing-video-11-15-08-camber-link-bushing.jpg
joey is offline
Old 11-15-2008, 04:52 PM   #3 (permalink)
It does look like that bushing is ripped,
We inspect all of the bushings with our eye's and pry bars, the pry bars allow us to move it and see play, rips, and other problems.
The upper control arm bushings in the front are best checked with the sheels off, but the suspension loaded (jack under the lower arm) and using a pry bar to check for movement and such.
Do you know if there is a Pedders dealer near you?
Old 11-15-2008, 05:30 PM   #4 (permalink)
Member Number: 232
Do mean shell instead of sheels? Is the shell shown in this pic?
There is a Chevy dealer in Fairfield that is supposed to be a Pedders dealer.
But I didn't have a great experience with them, and the Pedders trained tech had quit a few days before my bumpsteer install. I don't know if they found or trained a new Pedders tech.
joey is offline
Old 11-15-2008, 06:16 PM   #5 (permalink)
I'm not sure on the status of Fairfield
sheel = wheel
Old 11-20-2008, 10:39 PM   #6 (permalink)
Added footage with the Pedders bushings installed to show the difference in movement.
YouTube - LX Radius Rod Comparison - Worn OE vs Pedders
Old 11-22-2008, 07:31 PM   #7 (permalink)
dms
Points: 3,166, Level: 1 Points: 3,166, Level: 1 Points: 3,166, Level: 1
dms's Avatar
Car: 2006 Pontiac G/P
Member Number: 16007
sheel = wheel
Fairfield is no longer a Pedders Dealer. We have 2 new dealer popping up in the SF bay area. In the interrum, I can assist the SF bay area needs
thanks
mike
dms
A
Michael White
Pedders West Coast Manager
mike.white@PeddersUSA.com
925-215-1308
Videos of Stock OEM bushes
dms is offline
Old 11-22-2008, 07:49 PM   #8 (permalink)
Points: 3,663, Level: 1 Points: 3,663, Level: 1 Points: 3,663, Level: 1
Activity: 30% Activity: 30% Activity: 30%
NWH_300C's Avatar
Car: 2006 Chrysler 300c Magnesium Pearl
Member Number: 15764
who supplies pedders in the bay area, and what mileage is typical for the install?
NWH_300C is offline
Old 11-22-2008, 08:56 PM   #9 (permalink)
dms
dms's Avatar
I currently do. I live in Livermore. We have done installs as low as 600 miles to as high as 80K plus.
What are you interested in?
mike
dms
dms is offline
