Old 11-20-2008, 08:16 AM   #1 (permalink)
Points: 1,766, Level: 1 Points: 1,766, Level: 1 Points: 1,766, Level: 1
Car: 2005 chrysler 300c
Member Number: 18320
Tie rod end's replaced.....
Just got my car back from the dealership after having the tie rod ends replaced, and they tell me they don't align the front end!!!!!
They claim they have set the toe and this is sufficient. Didn't want to argue with this older woman who was giving me my keys back so i was wondering what you guys had to say about this. They want 100 bucks to align the front and back end.
Does the rear end even need to be aligned??
Has anyone just went with out the alignment?
Car will drift a little now and agian.
DWN LOW Racing has now merged with Mopar
05 300c De badged
22" dub's wrapped in 265/25/22 Pirelli's
2 800 watt VOLFENHAG 10" Subs
2 800 watt 6x9's VOLFENHAG
1800 watt Pyramid Amp (been through 2 trucks and 3 accidents this thing is bullet proof)
touchscreen for Christmas??????
Mr.Craig is offline
Old 11-20-2008, 09:59 AM   #2 (permalink)
Points: 3,874, Level: 1 Points: 3,874, Level: 1 Points: 3,874, Level: 1
Car: 2006 Chrysler 300 srt8-every available option
Member Number: 1578
when I had my tie rods replaced, the dealer told me the same thing, that the set the toe, and road tested it and it was fine. I didn't have a problem, but a few months after that I got four new tires, and a 4 wheel alignment. yes there is an adjustment for the rear, as well as the front.
wantit is offline
Old 11-20-2008, 10:30 AM   #3 (permalink)
What exactly is a rear end alignment?
Mr.Craig is offline
Old 11-20-2008, 11:19 AM   #4 (permalink)
Points: 4,078, Level: 1 Points: 4,078, Level: 1 Points: 4,078, Level: 1
Member Number: 2790
Technically the dealer is correct, the tie rods have no impact on caster and camber settings. They only affect the toe setting. So setting the toe should be sufficient, provided the car is OK otherwise. Of course, the only way to know that is to check. Personally, I'd get the car aligned.
Phil
2006 300C
Brilliant Black
phunter1 is offline
Old 11-20-2008, 08:17 PM   #5 (permalink)
Points: 127,841, Level: 1 Points: 127,841, Level: 1 Points: 127,841, Level: 1
Member Number: 232
Toe, thrust and maybe steering wheel centering are the only things adjusted during a "normal" alignment.
Our camber and caster should never need to be adjusted.
In the unlikely event camber and caster becomes out of spec then cradle and/or bolt adjustments are needed.
From the Service Manual
CAMBER AND CASTER
Camber and caster settings on this vehicle are determined at the time the vehicle is designed, by the location of the vehicle’s suspension components. This is referred to as NET BUILD. The result is no required adjustment of camber and caster after the vehicle is built or when servicing the suspension components. Thus, when performing a wheel alignment, caster and camber are not normally considered adjustable angles. Camber and caster should be checked to ensure they meet vehicle specifications.
If individual front camber or caster is found not to meet alignment specifications, each can be adjusted by shifting the engine cradle if cross-camber and cross-caster are within specifications, or by using an available service adjustment bolt package. Always try to shift the cradle first (if camber and caster are off slightly) to correct the mis-alignment before installing an adjustment bolt package. If an adjustment bolt package installation is necessary, inspect the suspension components for any signs of damage or bending first.
joey is online now
Old 11-21-2008, 10:53 AM   #6 (permalink)
Member Number: 2790
Thanks Joey,
l learned something about our cars that I didn't know.
Phil
phunter1 is offline
Old 11-21-2008, 03:17 PM   #7 (permalink)
Points: 5,014, Level: 1 Points: 5,014, Level: 1 Points: 5,014, Level: 1
Member Number: 14575
Trader Rating: (6)
hey i recognize those wheels did you buy them off a guy in Cali?
Nok 300C
Mods: 11db Blastin Bobs, E. Cutouts, BT knobs, switches, shifter, LED tails, SRT suspension, shaved Doors w/Poppers, Polished hood Shocks, Engraved rotors , Xenon body kit w/molded rear lip, deep dish grille w/polished vertical inserts, vented fenders, matte purple paint, welded eyelids, filled trunk, filled squirter holes, air ride, 22" chrome srt reps, colormatched/engraved caliper covers, SS brake lines, RE front and rear strut bars, full wrap interior, molded LED side mirrors
Big Daddy J 300 is offline
Old 11-22-2008, 07:35 PM   #8 (permalink)
dms
Points: 3,101, Level: 1 Points: 3,101, Level: 1 Points: 3,101, Level: 1
dms's Avatar
Car: 2006 Pontiac G/P
Member Number: 16007
the OEM suspension on a LX will only allow you to "set the toe and let it go" front and rear. There are no camber caster adjustments. The only thing you can do on the front is to relocate the front engine cradle, but the amount of movement is not very much
So if they only set the toe and let it go, why do the Chrysler dealers still charge you for a 4 wheel alignment??
mike
dms
A
Michael White
Pedders West Coast Manager
mike.white@PeddersUSA.com
925-215-1308
Videos of Stock OEM bushes
dms is offline
Old 11-22-2008, 08:17 PM   #9 (permalink)
Member Number: 232
mike
dms
I think more and more new model cars are being designed like the LX, only a toe adjustment is needed. Most alignment shops have not changed their old "one price fits all" alignment pricing. They obviously don't want to offer a lower price if they don't need to.
I did get the Chevy Fairfield dealer to lower their alignment charge from about $130 to $80 after my bumpsteer kit install.
But other alignment shops won't lower their price for just a toe adjustment.
The alignment shops do need to set up all the alignment equipment on each wheel, but their overall labor time is reduced to just setting the toe.
joey is online now
Old 11-24-2008, 01:08 PM   #10 (permalink)
Points: 3,748, Level: 1 Points: 3,748, Level: 1 Points: 3,748, Level: 1
Member Number: 7149
I use to run into the issue when getting an alignment for a FWD 1990 Plymouth Laser turbo I owned.
Per the service manual, the only adjustment was for the front toe. No other adjustments were possible, yet everyone wanted to do a 4 wheel alignment.
So, I found a way around it. I use to ask what they charged to align a Chevy Chevette. That car only had toe adjustment, and I find alignments to run under $50 for them. So, that's what I would request for my Laser...toe only, thank you very much.
Chase300 is offline
