Old 03-27-2009, 04:25 AM   #21 (permalink)
Points: 612, Level: 1 Points: 612, Level: 1 Points: 612, Level: 1
Car: 2007 Chrysler 300c
Member Number: 18780
Here is my mates on 22's with shorter shocks and a small notch for the upper arm to go lower
If you go to low the drive shaft hits the suspension cradle
The front has no mods and runs the inner plastic
Rears are 22x10's as well
300climo is offline
Old 03-30-2009, 10:31 PM   #22 (permalink)
GROUNDED's Avatar
Member Number: 10038
I noticed that when I was running air on my stock wheels
I had some rubbing from my half shaft on the rear cradle. On bigger wheels I think this may be more of a problem with more tuck. I have holes in my factory plastic liner now so I can easily see what is holding me up. At some point I will cut it for a 24/26 but that will be years down the road.
GROUNDED is offline
Old 03-30-2009, 11:13 PM   #23 (permalink)
This car had the same issue
The bag bracket was raised a little to stop it
You would need to notch the cradle to get it any lower on 22's
300climo is offline
Old 03-31-2009, 07:29 AM   #24 (permalink)
GROUNDED's Avatar
I think thats my plan, I have some extra DOM tubing I can notch into it.
GROUNDED is offline
Old 04-10-2009, 04:21 PM   #25 (permalink)
Points: 4,256, Level: 1 Points: 4,256, Level: 1 Points: 4,256, Level: 1
Car: 2005 300c 300c
Member Number: 12274
Send a message via AIM to SYS300C
that 300c is sick
SYS300C is offline
