Old 03-16-2009, 11:11 PM   #1 (permalink)
Points: 751, Level: 1 Points: 751, Level: 1 Points: 751, Level: 1
Rob3980's Avatar
Car: 2005 Chrysler 300c AWD
Member Number: 21179
Cut springs???
I just had my eibach springs installed and the car doesn't sit as low as I'd like it too. I also just ordered my 22" wheels is it possible to cut a coil off of each one of the springs or will it not work and if it will, will the ride be worse off ? And if I did cut a coil would I have a rubbing issue with my 22's?
Rob3980 is offline
Old 03-16-2009, 11:40 PM   #2 (permalink)
Points: 86,191, Level: 1 Points: 86,191, Level: 1 Points: 86,191, Level: 1
Activity: 83% Activity: 83% Activity: 83%
Rambit's Avatar
Car: 2005 300C SRT8
Member Number: 1493
Trader Rating: (6)
This has been discussed in the past and the overwhelming consensus is DON'T DO IT!
Cutting springs?
cutting stock springs
Bernie
Rambit is online now
Old 03-17-2009, 08:31 AM   #3 (permalink)
Rob3980's Avatar
Ok thank you
Rob3980 is offline
Old 03-18-2009, 02:00 PM   #4 (permalink)
Points: 13,031, Level: 1 Points: 13,031, Level: 1 Points: 13,031, Level: 1
Flossin22s's Avatar
Car: 2006 chrysler 300
Member Number: 2931
u can remove the rubber isolators in the back and the bottom one on the front strut to lower it a bit more
Flossin22s is offline
Old 04-12-2009, 09:39 AM   #5 (permalink)
Points: 1,741, Level: 1 Points: 1,741, Level: 1 Points: 1,741, Level: 1
Activity: 52% Activity: 52% Activity: 52%
Concrete's Avatar
Car: : : :
Member Number: 21143
Two questions...
About how much would it lower the car...and...
Would any problems uproot once performed?
(Referring to Flossin's statement)
Concrete is offline
Old 04-13-2009, 02:51 AM   #6 (permalink)
Flossin22s's Avatar
Member Number: 2931
all u need here
http://www.***************/showthread.php?t=64023
Old 04-13-2009, 08:01 AM   #7 (permalink)
Points: 6,968, Level: 1 Points: 6,968, Level: 1 Points: 6,968, Level: 1
GROUNDED's Avatar
Member Number: 10038
Originally Posted by Flossin22s View Post
wow now blocking links is real big of this forum lol..
http://www.300cforum z.com/showthread.php?t=64023
anways I used google to find the thread that flossin went out of his way to post. To go to the page at the z forums just copy the link and remove the space between forum and z.
GROUNDED is offline
Old 04-14-2009, 10:46 PM   #8 (permalink)
Points: 4,256, Level: 1 Points: 4,256, Level: 1 Points: 4,256, Level: 1
Car: 2005 300c 300c
Member Number: 12274
Send a message via AIM to SYS300C
rob... here you go
SYS300C is offline
Old 04-15-2009, 12:15 AM   #9 (permalink)
Rob3980's Avatar
Holy sh+t man ur car is sick! How many coils u cut and how does it handle? Ne problems with ground clearance?
Originally Posted by SYS300C View Post
rob... here you go
Rob3980 is offline
Old 04-15-2009, 12:59 AM   #10 (permalink)
Points: 718, Level: 1 Points: 718, Level: 1 Points: 718, Level: 1
Car: 07 kawasaki ninja 06 300c .
Member Number: 21617
how much lower would you want to go??
maybe its because of where i live but i wouldnt want my daily driver that low, even when i lived in AZ and had my track car on the street it was still a pain in the neck because every driveway had a curb, good luck to you man i hope you get it set up how you want it
e-ville is offline
