Old 04-03-2009, 12:19 PM   #1 (permalink)
Points: 1,260, Level: 1 Points: 1,260, Level: 1 Points: 1,260, Level: 1
Car: 2005 chrysler 300
Member Number: 17427
Wheels are to wide for normal camber kit? Can I pull the wheels in from the bottom??
I have a 2005 300 limited, lowered 1.5 with 10'' wide 24's. I need to fix the negative camber problem but if I do I think the wheels will smash right into the fenders. I was wondering if they make any kits that pull the bottom of the wheel in rather then pushing the top of the wheel out like normal camber kits.
Please let me know if you know of anything to fix this. I only have about 7,000 miles on my tires and the insides are already worn out.
prestony889 is offline
Old 04-03-2009, 08:58 PM   #2 (permalink)
Points: 28,614, Level: 1 Points: 28,614, Level: 1 Points: 28,614, Level: 1
HEMMISSEY's Avatar
Car: 2005 300c VIP Modular Forged Wheels
Member Number: 983
have you looked into these kits?
http://cgi.ebay.com/ebaymotors/SPC-R...QQcmdZViewItem
<---12" WIDE---> Club
Last edited by HEMMISSEY : 04-03-2009 at 08:59 PM. Reason: oooooooooooooooooooooooops
HEMMISSEY is offline
Old 04-06-2009, 05:11 PM   #3 (permalink)
I have looked into those kits but they all adjust the camber from the top which will probaly push my tire into my fender. As of right now I can't even fit my fingers threw the gap of my tire and fender.
Old 04-06-2009, 05:35 PM   #4 (permalink)
Points: 21,257, Level: 1 Points: 21,257, Level: 1 Points: 21,257, Level: 1
Activity: 87% Activity: 87% Activity: 87%
Mr. iNCREDIBLE's Avatar
Member Number: 5683
Trader Rating: (21)
no, that is not how they work..
think about it:
if the tire is out at the bottom, then it is in at the top.... example:
negative chamber: / \
positive chamber: \ /
Correct chamber: | |
if you pull in the bottom, you push out the top, if you push in the bottom you pull out the top..
negative chamber occurs when you lower a car, the bottom of the wheel kicks out..
positive chamber occurs when you raise a car, the top of the wheel kicks out..
the SPC chamber kit above allows for 1.5 degrees of correction, either way..
if mounted with the offset bushing toward the outside of the car, it pulls the bottom of the wheel in from this: / to this |
if mounted with the offset bushing toward the inside of the car, it pulls the top of the wheel in from this: \ to this |
I had 1.3 degrees negative chamber on my 300 with a 3.5 inch suspension drop on coilovers... the SPC kit lined me up to a .02 degree positive chamber, and spec is + or - .05 degrees, so I am dead on spec..
I believe I can see the future, Cause I repeat the same routine.
Every day is exactly the same
Mr. iNCREDIBLE is offline
Old 04-06-2009, 05:42 PM   #5 (permalink)
Member Number: 5683
Trader Rating: (21)
oh yeah, and if correcting the chamber makes the wheel too close to the fender, then you need to roll your fenders..
Old 04-23-2009, 08:55 AM   #6 (permalink)
Thanks for the help everyone.
My fenders are rolled that's why I'm so worried about the tires hitting because I have no other options.
Old 04-23-2009, 10:59 AM   #7 (permalink)
Member Number: 5683
Trader Rating: (21)
what size tire are you running? (not wheel, the full tire size)
and can you post up a picture?
