It is my personal belief, and I am being honest, there are a lot more things to do before the 90/10s and 90/10s are for the very serious drag racers.
The back end of a LX has way too much loosensess and movement in the rear, and too much negative cambers. Fronts need to support the rear. At a minimum, they need front upper control arm bushings to adjust camber and caster, bump steer kit to assist straight line steering, and front radius rod to assist in front caster and toe stabilization. Rear coil rates need to increase, and damper rates for the rear need to be better matched to control the spring rates.
With all of this being done, then 90/10s will function much better.
mike
dms
