Old 05-20-2009, 12:00 PM   #1 (permalink)
Points: 3,181, Level: 1 Points: 3,181, Level: 1 Points: 3,181, Level: 1
Car: 2005 chrysler 300c
Member Number: 2525
anyone solved rear suspension noise
I have clunking noise coming from the rear
suspension. If anyone solved the noises coming
from the rear suspension, can u let me how
you solved them?
thank you for your help.
razor108 is offline
Old 05-20-2009, 12:18 PM   #2 (permalink)
Points: 21,257, Level: 1 Points: 21,257, Level: 1 Points: 21,257, Level: 1
Activity: 87% Activity: 87% Activity: 87%
Mr. iNCREDIBLE's Avatar
Member Number: 5683
Trader Rating: (21)
i never had clucking until I put on the TEIN coilovers.. as far as I can tell it is the upper spring seat causing it and I am changing mine out this weekend to see if it fixes it.. $7 rubber part.. I hope it does, been driving me nuts for a month.
I believe I can see the future, Cause I repeat the same routine.
Every day is exactly the same
Mr. iNCREDIBLE is offline
Old 05-20-2009, 12:58 PM   #3 (permalink)
Member Number: 2525
thank you for the info , i'm getting
air suspension soon and would like
to get as many ideas, so i can look
into it.(i have srt8 suspension on a 5.7)
razor108 is offline
Old 05-20-2009, 03:21 PM   #4 (permalink)
Member Number: 5683
Trader Rating: (21)
no problem, couple things to check when you do it..
check the 2 bushings on the Sway bar, when I installed my Hotchkis sways I noticed that I had lost one of the bolts on one of the bushings.. it backed completely out, 4 weeks after the Hotchkis install same thing happened again, one of the bolts backed out, this time I caught it before I lost it.. make sure to check them and use some locktite on them..
also as I said, my upper spring mounts are shot, I think putting the TEIN springs in finally cracked them to the point I am metal to metal on the spring seat (the spring seats are rubber pieces to prevent the metal to metal rubbing)
Old 05-20-2009, 05:50 PM   #5 (permalink)
Points: 3,890, Level: 1 Points: 3,890, Level: 1 Points: 3,890, Level: 1
dhoolwerf's Avatar
Car: 2007 Chrysler 300C SRT Design & 1967 Plymouth Belvedere II
Member Number: 17559
I, too, had clunking from the rear. It turned out to be a faulty shock absorber. Replaced under warranty. Nice and quiet once again.
dhoolwerf is offline
Old 05-20-2009, 06:18 PM   #6 (permalink)
Points: 10,619, Level: 1 Points: 10,619, Level: 1 Points: 10,619, Level: 1
wog boy's Avatar
Car: 2006 . 300c, rolling on 24's
Member Number: 5242
Sure that noise isn't a worn half shaft??
**My Youtube Video**
wog boy is offline
Old 05-20-2009, 07:48 PM   #7 (permalink)
Member Number: 2525
the drive shaft?
razor108 is offline
Old 05-21-2009, 11:11 AM   #8 (permalink)
Member Number: 5683
Trader Rating: (21)
mine? no my rear end and half shafts are brand new, have under 1000 miles on them....
Old 05-28-2009, 09:32 AM   #9 (permalink)
wog boy's Avatar
Member Number: 5242
Na Mr I, i was thinking about Razors', I know you car has had everything replaced except the kitchen sink
wog boy is offline
