Originally Posted by RolexRoller
The inner tie rod is only a shaft and doesn't need to be serviced nor does it get loose. the inner tie rod doesn't have an end like the outside.
This is coming directly from the service manual. Look it up for yourself.
You are working with old data. Chrysler has even published an update to the field service manual with instructions on how to replace the inner tie rods.
Attached is a copy of the instructions. Ignore the red "Demo Version".
I had to download a free demo program to convert an excel file to pdf.
Edit -
The PDF conversion didn't work that great.
Here is a link to the Excel file.
http://www.datafilehost.com/download-56c5428e.html
