Old 06-19-2009, 09:01 PM   #11 (permalink)
Points: 21,813, Level: 1 Points: 21,813, Level: 1 Points: 21,813, Level: 1
Mr. iNCREDIBLE's Avatar
Member Number: 5683
Trader Rating: (21)
Originally Posted by 300C-hris View Post
I just received my dc SB...but I don't kknow what it is it doesn't fit... Any one have complications on the DC strut bar??
More info needed. Why doesn't it fit? Got pics?
When I first tried to install my DC strut bar the 3 strut bolts on my KWv2's didn't line up with the strut bar holes.
I had to take off each wheel and turn the strut so the bolts lined up.
need to raise the front of the car, put it on jack stands, make sure the wheels are at least 2 inches off the ground..
after you unbolt the 6 shock tower bolts when the car is raised, you can shim the bolts as needed to align the DC brace..
with the wheels on the ground you aren't moving anything..
the stock shocks have .5 - 1.5mm of wiggle room when the bolts are loose and the wheels off the ground..
I believe I can see the future, Cause I repeat the same routine.
Every day is exactly the same
Mr. iNCREDIBLE is offline
Old 06-19-2009, 10:22 PM   #12 (permalink)
Member Number: 232
I wasn't sure how to line up the bolts, so I removed the wheel and took my KWv2 spanner wrench and started to lower the perch to take tension off the strut mount. On my first pull on the spanner wrench the strut/shock turned just enough and the 3 bolts aligned perfectly with the strut bar. Dumb luck.
joey is online now
Old 06-26-2009, 02:24 AM   #13 (permalink)
Points: 3,485, Level: 1 Points: 3,485, Level: 1 Points: 3,485, Level: 1
Car: 2006 chrysler 300c AWD BS
Member Number: 7073
Trader Rating: (12)
Send a message via AIM to ajn096/300c AMG
rear srut
what does the rear strut bar do for the ride & handeling?
ajn096/300c AMG is offline
Old 07-25-2009, 05:14 AM   #14 (permalink)
Member Number: 7073
Trader Rating: (12)
reazes edge by far
I'am with bruno RAZORS EDGE great bar,it works with your engine cover in place, i hade mine airbrushed to match engine cover looks great as well,next mod, rear REAZORS EDGE strut bar. these bars are 4-point installation. i think thy are better than the DC,and Mopar. i payed $150.00 from HHP RACE.COM the rear is $150.00 aswell.
Old 07-26-2009, 12:50 PM   #15 (permalink)
Points: 10,195, Level: 1 Points: 10,195, Level: 1 Points: 10,195, Level: 1
UK CHRYSLER 300C's Avatar
Member Number: 12398
old skool here,if you have to lift the car and move the mounting bolts then you have shifted the angle of the suspension(not a good thing if you dont know what you're doing)I,on the other hand would have filed,or slightly enlarged the holes out on the strut bar mount holes so nothing on the suspension tops have moved from factory drillings
4300k hid main lights
4300k hid fog lights
RS UV-1, 20" alloys
next upgrade when the £ is stronger is a SuperCharger + Nitrous
UK CHRYSLER 300C is offline
