Im having problem putting together the front air bag and struts on the mounting plates. My air line fitting does not clear the koni strut base seat where the bracket and bag set.The screw holes are not lining up correctly. If any had this issue, please give me some help with this one. I do not want to tighten the fitting to tight or strip the tread. also does the uas kit come with braided air line for the front? if so I do not have them. I seen other that has uas kit w/braided front air lines.
here are some pics of what I'm talking about.
See in these pictures, it not sitting flush with the bottom for the base of strut.the picture above, the air fitting bolt should be flush with the bracket base, which it sticks up some. Not allowing the air bag not to seat flat on the strut. any help with problem would be helpful, thanks
Edit/Delete Message
