Old 08-04-2009, 04:42 PM   #1 (permalink)
Points: 132, Level: 1 Points: 132, Level: 1 Points: 132, Level: 1
Car: 2007 Chrysler 300C
Member Number: 23215
Alignment? What alignment?
This is the second 300c I've owned and both had the same problem of pulling to the left even though it's claimed to be within specs on the rack. WTF! Before I check myself in I thought I'd just see if I'm alone on this one.
MLKRYSS is offline
Old 08-04-2009, 05:33 PM   #2 (permalink)
Points: 527, Level: 1 Points: 527, Level: 1 Points: 527, Level: 1
whitec's Avatar
Car: 2005 Chrysler 300c
Member Number: 23099
I have one I just repaired and noticed the front ends have adjustments in the front/rear lower control arms(3 separate slots in the control arm side that mount to the engine cradle) The ball joints are not adjustable from the factory but you can install aftermarket ones that are adjustable and greasable too. Bring the car to an experienced alignment shop and they should be able to straighten this out. Go to a collision shop if you have one in the area and ask if they do alignments or can recommend someone to do it for you. Most places will not go through the effort of unbolting control arms and moving them. These cars are definetely not one of the easier cars to align.
whitec is offline
