Old 08-22-2009, 02:17 PM   #1 (permalink)
Points: 7,909, Level: 1 Points: 7,909, Level: 1 Points: 7,909, Level: 1
saleensean's Avatar
Car: 05 dodge magnum
Member Number: 2633
help needed.. UAS switch
i have the 3way ashtray switch and my front will not go up. i looked at the wiring on the back of the switch and noticed a white wire came off. can someone that has this set up take a look at the back of the switch and tell me where this wire goes. i need to get the front up.....
thank you.
saleensean is offline
Old 08-24-2009, 10:27 AM   #2 (permalink)
Points: 5,286, Level: 1 Points: 5,286, Level: 1 Points: 5,286, Level: 1
Member Number: 5047
The white wire should be on the other end of the switch with the green wire. So depending on how you hold it, if you have the green on the top right switch, the white is the bottom right.
If you want to email a pic to zack@universalairsuspension.com i will point to it.
-Zack Ratcliff
800-864-2470
Old 08-25-2009, 10:12 PM   #3 (permalink)
saleensean's Avatar
Member Number: 2633
thank you.
