Old 09-11-2009, 12:07 AM   #1 (permalink)
Points: 5,731, Level: 1 Points: 5,731, Level: 1 Points: 5,731, Level: 1
Car: 2006 Chrysler 300 LX
Member Number: 14521
tank locations
ok guys so any ideas of putting smaller air tanks anywhere besides taking up the trunk? i really want to add another tank but I dont have a frickin clue where i could mount it.
Dove dkla is offline
Old 09-11-2009, 12:39 AM   #2 (permalink)
Points: 6,036, Level: 1 Points: 6,036, Level: 1 Points: 6,036, Level: 1
CoolVSRT8's Avatar
Member Number: 18060
perhaps under the rear bumper? thats where the twin turbos would go on our cars, that is SOLID metal
2005 Cool Vanilla 300C SRT8 1 of 1
Waiting impaitently for the track to open!
CoolVSRT8 is offline
Old 09-11-2009, 12:48 AM   #3 (permalink)
Points: 771, Level: 1 Points: 771, Level: 1 Points: 771, Level: 1
Member Number: 20634
not into the under the car tanks or even mounting the valves behind the bumper a rear and accident could leave you stuck... i think i would have a tank made to go on the opposite side of the trunk from the stock sub might be expensive but out of the way....
Bigal470 is offline
Old 09-11-2009, 01:51 AM   #4 (permalink)
CoolVSRT8's Avatar
good call big al i didnt think of the accident part doh!
Dove show us a picture of what your working with so far
Old 09-11-2009, 11:16 AM   #5 (permalink)
GROUNDED's Avatar
Member Number: 10038
The tanks need to be cylindrical in shape so a custom tank is kind of out of the question. Not to mention it needs to be welded by a welder certified to weld on pressure vessels. I run 2x 5 gallon stainless tanks in my trunk but they are mounted to the floor under the rear speakers. Question is #1 how much are you looking to run and #2 How ambitious are you. I know firestone makes 1.5 gallon tanks and you could easily stuff these where the resonators go under the car and by putting 1 on each side you will pick up 3 extra gallons. If you are worried about these getting hit in an accident then throw a ball valve on the airline that connects the tanks so you can essentially shut of any particular tank if it begins to leak for whatever reason.
GROUNDED is offline
Old 09-12-2009, 02:48 AM   #6 (permalink)
really ive seen plenty of square tanks as long as the walls are think enough its no problem ive even heard of the truck guys boxing in there frame rails and using them for tanks...
Bigal470 is offline
Old 09-12-2009, 09:55 PM   #7 (permalink)
GROUNDED's Avatar
I too have seen frames as tanks. I wouldn't recommend a square tank for a car. The walls would have to be something like 1/4" thick. Trick tanks can make aluminum 1 off ones for air fyi.
GROUNDED is offline
Old 09-12-2009, 11:51 PM   #8 (permalink)
Points: 10,309, Level: 1 Points: 10,309, Level: 1 Points: 10,309, Level: 1
Simans82's Avatar
Car: 2007 Chrysler 300C SRT8
Member Number: 3988
Here are some thoughts and ideas from the air ride guru himself.
Originally Posted by Blowndakrt View Post
Well if anyone has been thinking about going with air ride, but want to keep their trunk space, I have figured out a way to get both.
When I was told about the new prototype tanks coming out from UAS, I told Zack I wanted 3 of them. My old setup, I ran 2 5 gallon tanks and wanted more air on tap. So Zack sent me 2 of the new chromed aluminum and 1 of the new silver aluminum tanks.
As most of you know my trunk is pretty full with audio stuff and my air ride components, so I needed a place to mount my third tank.
After messing around with several different options, I found a nice place to mount it. I had the fascia off when I was installing my Halo head lights and new grill and got to looking at the bumper area. After a few measurements in my head, I knew I could fit a tank there. The 5 gallon was a little too big to fit in there for my comfort level, but the new 4 gallon tanks from UAS fit like a glove. It was not necessary, but I cut off the legs on the tank. I wanted it to look cleaner, so it was more for visual than clearance.
Here are some pics.
And with the factory foam padding installed. I had to do some trimming on the bottom edge to get it to sit flush against the bumper again.
And some pics of how low it sits. Some were worried that it would hang down too low and cause issues. But a little fab work on the brackets and it sits higher than the front crossmember as well as the bottom of the radiator.
The front fascia still fits without any issues. I actually have about 2 inches between the tank and the front fascia.
So you can't use the "I need my trunk space" as an excuse for not going air ride anymore. LOL. There is also room to mount 2 compressors up in the bumper area as well. For now, I am fine with my 6 compressors down in the spare tire well. But I like the option of being able to add more later on if I desire.
Shawn
Simans82 is offline
Old 09-12-2009, 11:52 PM   #9 (permalink)
Simans82's Avatar
Member Number: 3988
I don't know what's up with the pics... maybe a Photobucket problem.
Simans82 is offline
Old 09-12-2009, 11:57 PM   #10 (permalink)
Simans82's Avatar
Member Number: 3988
Well here's a few pics:
Simans82 is offline
