Old 09-22-2009, 01:15 PM   #1 (permalink)
Points: 207, Level: 1 Points: 207, Level: 1 Points: 207, Level: 1
Car: 2002 Dodge Ram 1500
Member Number: 23463
eibach sportlines on stocks?
anyone got these on a silver 300c? Planning on getting these springs soon. Although UAS was my original plan, cant afford at the moment but i also cant drive stock height any longer. post what you got.
Three00See is offline
Old 09-22-2009, 01:21 PM   #2 (permalink)
Points: 4,261, Level: 1 Points: 4,261, Level: 1 Points: 4,261, Level: 1
Big D's 300C's Avatar
Member Number: 8065
Texas 300C has these on his silver C. He should be along shortly to post his pics.
Big D's 300C is offline
Old 09-22-2009, 01:22 PM   #3 (permalink)
Member Number: 8065
Here's the post. 22's with Eibach Pro Kit
Old 09-22-2009, 01:41 PM   #4 (permalink)
Points: 10,309, Level: 1 Points: 10,309, Level: 1 Points: 10,309, Level: 1
Simans82's Avatar
Car: 2007 Chrysler 300C SRT8
Member Number: 3988
When you say "on stocks" I'm assuming you mean on stock wheels? Or do you mean stock shocks? I've had the Sportlines, but only on stock SRT 20's and then 22's. I sold mine to Texas300C, but I don't believe he has pictures on the stockers either. Regardless, here's a few pics.
Sportlines with rear isolators removed on 245/45/20 front, 255/45/20 rear:
Sportlines with rear isolators removed on 265/30/22's:
Sportlines with rear isolators removed on 265/35/22's:
Simans82 is offline
Old 09-22-2009, 03:40 PM   #5 (permalink)
Points: 186, Level: 1 Points: 186, Level: 1 Points: 186, Level: 1
Car: 2008 chrysler 300c
Member Number: 23143
yea i dont have any pics of it on stockers just the 22s,
texas300c is offline
Old 09-22-2009, 07:54 PM   #6 (permalink)
Points: 1,970, Level: 1 Points: 1,970, Level: 1 Points: 1,970, Level: 1
Activity: 56% Activity: 56% Activity: 56%
Concrete's Avatar
Car: : : :
Member Number: 21143
That stance looks different with the rear isolators removed... How hard is it to remove them?
Concrete is offline
Old 09-22-2009, 08:00 PM   #7 (permalink)
i had a shop install the springs for me, but there just sitting on the top on bottom of the spring, if you can get the springs off, then u should be able to just pull them out no problem. maybe simans will chime in with more info on em
Old 09-23-2009, 07:26 AM   #8 (permalink)
Simans82's Avatar
Member Number: 3988
You got it. Remove the rear spring, and pull off the top and bottom isolators. They'll most likely just fall off when you remove the spring from the perch.
Simans82 is offline
Old 10-26-2009, 09:58 AM   #9 (permalink)
Points: 1,052, Level: 1 Points: 1,052, Level: 1 Points: 1,052, Level: 1
Member Number: 20303
Sorry to bring this back, but what is the purpose of the isolators? is there any effect on the handling/feel? Thanks for the info.
Stock 2006 3ooC
charliedrums is offline
