Old 09-25-2009, 05:59 PM   #1 (permalink)
Points: 4,469, Level: 1 Points: 4,469, Level: 1 Points: 4,469, Level: 1
Member Number: 199
Is There a Mod to Completely Defeat Traction Control?
If so where can I buy it?
Thanks.
Alex
2005 Dodge Durango Limited, (HEMI) loaded.
2006 Chrysler 300C
alextaylor29 is offline
Old 09-25-2009, 06:47 PM   #2 (permalink)
Points: 654, Level: 1 Points: 654, Level: 1 Points: 654, Level: 1
Member Number: 23719
I know that there is a place that sells the mod for this but I cannot remember where I have seen it. Also, there is a way to just wire in your own switch to turn the ESP completely off. I think you can even do it with the Predator but I am not sure. Hopefully someone else will have more info for you than I do. Sorry.
Big Daddy D 300C is offline
Old 09-25-2009, 08:34 PM   #3 (permalink)
Points: 1,052, Level: 1 Points: 1,052, Level: 1 Points: 1,052, Level: 1
Member Number: 20303
I think if you use the predator or maybe even the $5 eps defeat switch, you'll also turn off your antilock brakes. Anyone else want to correct this?
Stock 2006 3ooC
charliedrums is offline
Old 09-26-2009, 01:31 PM   #4 (permalink)
Points: 703, Level: 1 Points: 703, Level: 1 Points: 703, Level: 1
Car: 2008 Chrysler 300C AWD Steel Blue Metalic
Member Number: 21003
while driving 10 mph turn the key to the on position until the eps bas and mr squiggles lights come on
PMC413 is offline
Old 09-26-2009, 08:40 PM   #5 (permalink)
Points: 4,152, Level: 1 Points: 4,152, Level: 1 Points: 4,152, Level: 1
BigKent's Avatar
Member Number: 5621
Send a message via AIM to BigKent
I have a Predator, I know you can turn off the ESP with it, does it really disable the ABS too?
Keep in mind that the 300C is has an "open diff" rear end, the ESP "traction control" apply's breaks as necessary to allow both wheels to get power. With the ESP disabled you will be burning all the rubber off you right rear tire only, lame...
BigKent is offline
Old 09-27-2009, 12:21 AM   #6 (permalink)
Points: 2,329, Level: 1 Points: 2,329, Level: 1 Points: 2,329, Level: 1
Moebius44's Avatar
Car: 2005 Dodge Magnum
Member Number: 10921
Interrupting the PWR to the dynamic sense module will allow you to do the fun stuff (slide sideways etc). The idea is to install a momentary-off switch that temporarily powers down the DSS module, the PCM (by-way of CAN bus) no longer listens/responds to G data until the next key cycle.
HEMISSARY
Moebius44 is offline
Old 09-27-2009, 10:07 AM   #7 (permalink)
Points: 4,894, Level: 1 Points: 4,894, Level: 1 Points: 4,894, Level: 1
robaustin's Avatar
Member Number: 11195
Have s look at this older post for defeating the yaw sensor so you can do donuts without the stability control interfering with your fun. Turning traction control off with the Predator will turn off everything and you will probably end up in limp mode. Turning it off with the Predator is only meant for tuning on the dyno.
Custom No-ESP Mod on 2005 300C *PICS
Magnesium Pearl
Hotchkis Sway Bars
22Elite Console Cover & door elbow pads
Edashkit Real California Walnut Kit
BT catch can & pink thingy replacement
Diablo Predator CAI + 91 tune
no name CAI, similar to Air Hammer
MotoRad 4127 Thermostat
Conti's
robaustin is offline
Old 09-29-2009, 05:49 PM   #8 (permalink)
Member Number: 199
OK so.....what should I do or just deal with it as is?
Old 10-27-2009, 10:08 AM   #9 (permalink)
Points: 1,783, Level: 1 Points: 1,783, Level: 1 Points: 1,783, Level: 1
Car: 2006 Chrysler 300C HEMI Protection/Navigation & Sound Groups II
Member Number: 15353
Come on, it's much easier!
There is a certain firmware for PCM has what you want.
toshik is offline
Old 10-27-2009, 12:38 PM   #10 (permalink)
Points: 3,748, Level: 1 Points: 3,748, Level: 1 Points: 3,748, Level: 1
Member Number: 7149
Thanks.
Alex
Yes.
Right here...
No ESP, complete SRT-Style ESP Disable Solution
Chase300 is offline
