Old 10-09-2009, 07:43 PM   #11 (permalink)
Points: 1,293, Level: 1 Points: 1,293, Level: 1 Points: 1,293, Level: 1
Car: 2006 Dodge Magnum SRT8
Member Number: 20604
Send a message via MSN to viper3ez Send a message via Yahoo to viper3ez Send a message via Skype™ to viper3ez
Originally Posted by GROUNDED View Post
I believe they stagger the bag towards the inside to clear the shock. I know their rear mounts don't mount like the UAS ones do. They run a cup on top but instead of a cup on the bottom they have a plate that bolts to the lower arm.
you are correct sir. the bag mounts to a plate at the bottom and the cup at the top is staggered in a way it pushes the bag away from the shocks. but with my fatter shocks, it looked like it would still make contact inflated while i had the car on lifts but i think that would change by the time the car sits on the ground. have not had a chance to go under and check yet.
oh and the bag fits perfectly on the UAS kit. i actually tested my Re-6 bags on my UAS brackets.
get a UAS kit and you should have no problem
viper3ez is offline
Old 10-11-2009, 09:16 PM   #12 (permalink)
GROUNDED's Avatar
Member Number: 10038
It will bolt to the cup but the cup is set for a bag that compresses differently then the slam bag. The offset in the plate is essential to clear the shock.
GROUNDED is offline
Old 10-12-2009, 11:14 AM   #13 (permalink)
Points: 5,286, Level: 1 Points: 5,286, Level: 1 Points: 5,286, Level: 1
Member Number: 5047
Make sure you double check the upper arm when the bag is fully inflated.
-Zack Ratcliff
800-864-2470
Old 10-14-2009, 01:50 AM   #14 (permalink)
Points: 229, Level: 1 Points: 229, Level: 1 Points: 229, Level: 1
Car: 2009 chrysler 300
Member Number: 22967
What modifications will have to be done so that my 22 inch rims will fit within the wheel well wen I drop it as low as I can?
- 2009 Chrysler 300 -
- Eibach ProKit - 22" Chrome Rims - Chrome Dub Kit - E&G Phantom Grill - K2 Black Euro Headlights - 6000k Head/Fog HIDs -
- Eclipse AVN-726 Double Din - Dual 10" Kicker L7s - 1000.1 Kicker Amp -
j_murr27 is offline
Old 10-14-2009, 10:12 AM   #15 (permalink)
none, as long as you dont buy a ridiculously wide wheel. what wheels are u running?
viper3ez is offline
