Old 10-07-2009, 07:37 PM   #1 (permalink)
Points: 41, Level: 1 Points: 41, Level: 1 Points: 41, Level: 1
Car: 2005 CHRYSLER 300C
Member Number: 24027
05 300c 30000miles front end sounds loose ????
It sounds loose going over driveways and bumps hey guys thx for the help
WAYNE C is offline
Old 10-07-2009, 08:18 PM   #2 (permalink)
Points: 13,199, Level: 1 Points: 13,199, Level: 1 Points: 13,199, Level: 1
BIG SMOOTH's Avatar
Member Number: 7757
Trader Rating: (7)
Join the club....
There's tons of posts regarding this issue.
I've replaced/upgraded nearly every component in my front suspension and now my lower ball joints are shot to hell giving me the same "symptoms" you are experiencing now.
Yours first could be the infamous tie-rods. Get them checked out first and go from there.
"Stay classy San Diego!"
BIG SMOOTH is online now
Old 10-07-2009, 09:39 PM   #3 (permalink)
Points: 115, Level: 1 Points: 115, Level: 1 Points: 115, Level: 1
cleanpiper's Avatar
Car: 2005 chrysler 300c
Member Number: 23662
the cheapest place to start is with the swaybar bushings, ive spent about $800 chasing down my front end rumble and it ended up being the two bushings (about $30 each) im a licenced mechanic and working as a service manager myself and 6 other tech's took turns chasing tha noise down... do yourself a favour and start there
p.s you could also stick a piece of rubber under the exsisting bushing bracket such as a piece of timing belt and take it for a test drive as a way to test to see if those are the problem
hope this helps
cleanpiper is offline
Old 10-16-2009, 09:07 PM   #4 (permalink)
Points: 2,142, Level: 1 Points: 2,142, Level: 1 Points: 2,142, Level: 1
driftsucky's Avatar
Member Number: 16119
SWAY BAR BUSHINGS!!!!!! That's the place to start. Tech's will tell you tie rod ends. I had the same thing going on with my 300C and 12 bux later, it's fixed....with sway bar bushings. Me and my buddy Mike (certified Chrysler tech at a local Chrysler/Dodge/Jeep dealership) replaced them in about 20 minutes. After which he says "Oh, it worked. Usually it's the tie rod ends." I laughed and then rolled out with no rattle. It normally starts around 35-40k on the odo.
Dis sh1t right here ninja?
driftsucky is offline
