Old 11-03-2009, 01:23 AM   #1 (permalink)
Points: 1,983, Level: 1 Points: 1,983, Level: 1 Points: 1,983, Level: 1
PARGA88's Avatar
Car: 2005 chrylser 300
Member Number: 14989
what is cv joint/u joint??/
just as the title says...
pictures???
explanation?
cheap/expensive to fix/replace/repair??
thanks!!!
05 300c brilliant black
Exterior:
22' 365/35 Lexani lx-6 black option
de-badged
40% tint all around
magnaflow exhaust
EBC slotted/drilled brake rotors
Interior:
2 7' Performance tech headrest monitors
2 Performance tech. 2600w amps-subs
2 15' kicker l7's
2 Almani caps(2.0 FARAD)
Rockford Fosgate 3sixty processor
alpine amp-speakers
Mbquarts components
alpine 6x9's
DvD player
PARGA88 is offline
Old 11-03-2009, 02:03 AM   #2 (permalink)
Points: 10,198, Level: 1 Points: 10,198, Level: 1 Points: 10,198, Level: 1
UK CHRYSLER 300C's Avatar
Member Number: 12398
basically the cv joint is the bit that drives your hub where your wheels are attached,they're on the end of the driveshaft/axleshaft and they have bellows covering them to protct them.Do you have a problem with yours?are they clicking when you take up drive?
4300k hid main lights
4300k hid fog lights
RS UV-1, 20" alloys
next upgrade when the £ is stronger is a SuperCharger + Nitrous
UK CHRYSLER 300C is offline
Old 11-03-2009, 11:20 AM   #3 (permalink)
Points: 13,020, Level: 1 Points: 13,020, Level: 1 Points: 13,020, Level: 1
kevenj's Avatar
Member Number: 3126
pictures???
explanation?
thanks!!!
"CV" stands for "Constant Velocity" joint. You have an inboard CV joint (at the differential) and an outboard CV joint (at the wheel) on each drive axle, so your car has 4 total. These Joints allow the wheels to move up and down and stay in alignment while the wheels are turning. On front wheel drive cars they also allow the wheels to steer. Typically you would replace the axle with a remanufactured unit rather than replace an individual CV joint.
"U-joint" stands for "Universal Joint". These are the joints used in the driveshaft between the transmission and the differential. They don't allow as much range of motion as a CV joint does and are less expensive. But they are still necessary since there is some movement of the drivetrain due to engine torque (twisting motion). The engine, transmission, and differential are all mounted by rubber mounts so there is some movement.
Hope this helps.
kevenj is offline
Old 11-03-2009, 03:45 PM   #4 (permalink)
I was trying to keep it simple thats all,if you want the full blown version I will help you if you wish but you will get bored half way through,trust me,lol
Old 11-03-2009, 11:43 PM   #5 (permalink)
PARGA88's Avatar
thanks guys.while both your guys explanations were helpful, im more of a visual person:/
haha
im trying to figure out why my car has a slight shudder under exeleration, im trying to figure out if it has something to do with my rear right suspension tie rods, bushings, etc. or something with transmission/drive shaft
PARGA88 is offline
Old 11-04-2009, 01:25 AM   #6 (permalink)
Member Number: 232
Here are a couple of pics of the half shafts inner and outer cv joints/boots.
The Service Manual gives these possible causes of rear-end vibrations:
Vibration at the rear of the vehicle is usually caused by a:
² Damaged propeller shaft.
² Missing propeller shaft balance weight(s).
² Worn or out-of-balance wheels.
² Loose wheel lug nuts.
² Worn U-joints or CV joints.
² Loose/broken springs.
² Damaged axle shaft bearing(s).
² Loose pinion gear nut.
² Excessive pinion yoke run out.
² Bent halfshaft(s).
Vibration could also be tranny.
Water in the transmission is known to cause vibrations.
There is this TSB.
http://www.wkjeeps.com/misc/LX/TSB/TSB_2101105a.pdf
what-cv-joint-u-joint-cv-joint2.jpg   what-cv-joint-u-joint-cv-joint.jpg   what-cv-joint-u-joint-half-shaft.jpg
joey is offline
