Old 07-13-2005, 01:42 PM   #1 (permalink)
Buy Wheels Today
Member Number: 2515
Eibach springs in stock now !
We have Eibach springs in stock now for Chrysler 300 and 300C. We usually ship orders the same day and can deliver to most of the country in 2-3 business days.
Felix Canestri
Buy Wheels Today
866-747-6247
sales@buywheelstoday.com
BuyWheelsToday Website
Buy Wheels Today is offline
Old 07-18-2005, 08:13 PM   #2 (permalink)
-=SpeedFreak=-
-=SpeedFreak=-'s Avatar
Car: 2005 Fully Loaded Hemi-C 300
Member Number: 2029
Newbie Question
Felix;
I am currently running 20" rims on my 300c. I know there are people who run 22's. With 22's there is a nut from the coil/springs that MAY rub against the tires.
If I install the Eibach lowering kit, would I run into the issues of tires hitting the same nut?
Also what other suspension mods are available other than springs? I would like to quicken my steering and greatly reduce the body roll.
thanks
-=SF=-
-=SpeeedFreak=-
2005 300C Midnight Blue
E&G Grille / Chrome Pillars
255x45x20's on MC2-FZ16 Chrome Rims
Zoomers Cat Back Exhaust
Hotchkis Stage 1 TVS
SuperChips Tuner Currently running 91 Tune
www.ihatedell.net
-=SpeedFreak=- is offline
Old 07-19-2005, 07:30 AM   #3 (permalink)
Buy Wheels Today
Member Number: 2515
We have installed many sets of 20's and 22's on 300's. We have never run into a problem with this mythical nut. As long as you are using a wheel with the proper width and offset you should never have a problem with the 300 platform.
Eibach lowering kits are designed to fit perfectly with no modification to your car. At this time there are not too many options for suspension modification. The Eibach springs will be a great way to start building up your suspension by reducing body roll and increasing stability.
Old 07-19-2005, 11:56 AM   #4 (permalink)
djjasond
djjasond's Avatar
Car: 2006 Mafia Edition 300C
Member Number: 2311
Question for Buy Wheels-
I thought I read on this forum that the bolt is attached to a bar that moves up and down with the wheel... meaning that it is a fixed distance from the center of the wheel. Chances of rubbing only occur when you replace with a wheel tire package that is larger in overall diameter than stock - you actually make your tire closer to the bolt by using a larger diameter. In other words, lowering the vehicle would have no impact on the distance of the bolt from the tire. Can you confirm? This may put SF's mind at ease... if he has enought clearance now, he would retain that same clearance.
I've had my car for about a week and run 265/35/22 pirellis with 22" 9.5 TIS 03's with the 15mm offset and notice no difference in the distance of the bolt from the tire after putting on the eibach pro kit. I believe the one member who actually made contact with this bolt was running 265/35/22 that were 8 wide making them balloon quite a bit.
I think the eibach kit is an incredible mod and think as a sponsor you could do a lot to alleviate concerns about the notorious bolt.
Jason D
2006 Brilliant Black 300C, 22" TIS 03's, Eibach Pro-Kit, Zoomers Exhaust, E&G Mesh Grille & Lower Inserts, 35% tint, Lloyd custom hemi floor mats, Ultimate Pedals, Fat Mat throughout, Audio Control LC6, Phoenix Gold EQ, Rockford Fosgate Amps, Kicker 12" L5 Sub... to be continued.
djjasond is offline
Old 07-20-2005, 07:31 AM   #5 (permalink)
Buy Wheels Today
Member Number: 2515
Well put djjasond. The nut is in a fixed position. The only way it will rub on anything is if you use the wrong size tire or an improper wheel.
Make sure the tires you are using are no more than 29 inches in diameter. Using a wide tire on a narrow rim will cause the tire to ballon and sit taller than it was intended to. Call us if you have any questions or need more information on your custom set up.
The Eibach kit is designed to bolt on with out modification.
Old 07-20-2005, 10:07 PM   #6 (permalink)
PG300
Member Number: 2676
Angry Eibach Springs for AWD 300C
Has anyone found what suspension kit fits the AWD?
PG300 is offline
Old 07-20-2005, 11:33 PM   #7 (permalink)
teahead
teahead's Avatar
Member Number: 164
Will the springs for the 300c work for the srt-8?
NEXT MOD:
9" headrests, TVNav2Go
teahead is offline
Old 07-28-2005, 07:06 AM   #8 (permalink)
Buy Wheels Today
Member Number: 2515
I will call Eibach later today to verify SRT8 fitment.
Old 07-29-2005, 02:46 PM   #9 (permalink)
Buy Wheels Today
Member Number: 2515
Both kits, SRT8 and AWD, are still in the prototype phase of production.
Old 07-31-2005, 09:25 PM   #10 (permalink)
kcbiznite
Member Number: 3006
Send a message via AIM to kcbiznite Send a message via Yahoo to kcbiznite
rubbing?
whats up man i am running the exact same set up as you and i haven't even lowered my car yet and my rims are already rubbing. i bought the eibach springs and i took it to a shop and he said he wouldn't do it because the nut would hit the tire if i lowered it. what do i do? i am running 265/35/22 with 22" x 9.5 echelon rims. can you help me out with this? the guy at the shop said i need to buy airbags for my car.
kcbiznite is offline
