How to change out tie rod ends - Chrysler 300C Forum: 300C & SRT8 Forums
Suspension/Handling Modifications This section is for discussion of suspension related topics.
post #1 of 14 (permalink) Old 08-30-2010, 09:17 AM Thread Starter
Points: 358, Level: 1 Points: 358, Level: 1 Points: 358, Level: 1
Is there a good write up on here for this? Apologies in advance, I did do a search for it, but there was nothing real detailed. I've never changed out a tie rod end on any of the cars I have ever owned, so excuse my newbish question. I am going to get the Moog greasable ends of course.
Will I absolutely HAVE to have an alignment when I am done? Since I am changing out my tie rod ends, anything else I should do while I have it torn apart? Thanks in advance guys.
EDIT: Is it as simple as take off the two nuts, unthread the tie rod end and then reverse steps?
mrcooms is offline
post #2 of 14 (permalink) Old 08-30-2010, 09:57 AM
Points: 94,046, Level: 1 Points: 94,046, Level: 1 Points: 94,046, Level: 1
Tetris Champion
HPNO300's Avatar
Car: 2006 Chrysler 300 Touring and SRT8
Send a message via Yahoo to HPNO300
if i recall i think there might be a pretty good how to on lxf but i do remember seeing one some where though lol
HPNO300 is offline
post #3 of 14 (permalink) Old 08-30-2010, 10:15 AM Thread Starter
LOL thanks for the reply at the very least. Any idea if it is just as simple as just loosening the two nuts and replacing? Pepper in some swearing of course.
mrcooms is offline
post #4 of 14 (permalink) Old 08-30-2010, 05:44 PM
Points: 69,597, Level: 1 Points: 69,597, Level: 1 Points: 69,597, Level: 1
Yes.
Extraction of the ball joint stud after removal of the nut may require a pickle fork to get the tapered stud out of the hole. Tapping the threaded end of the stud with the nut brought to the end of the stud is an alternative. Don't damage the nut if it needs to be reused on the new stud. Applying some heat to the area surrounding the stud may help too.
All things being equal, count the number of threads exposed along the length of the tierod itself before unscrewing the end. Then thread the new end on and leave the same number of threads exposed. If the replacement end is the same as the original this will get you back to the same toe alignment. To avoid possible excessive tire wear you may want to get an alignment. The only alignment required would be the toe adjustment, so a full blown 4-wheel alignment is not necessary.
DESIREE is offline
post #5 of 14 (permalink) Old 08-31-2010, 08:08 AM Thread Starter
Originally Posted by DESIREE View Post
Yes.
Excellent, thanks!
mrcooms is offline
post #6 of 14 (permalink) Old 08-31-2010, 08:18 AM
Elite Contributing Member
Points: 88,746, Level: 1 Points: 88,746, Level: 1 Points: 88,746, Level: 1
Quiknen's Avatar
Car: 2005 Chrysler 300c AWD
Send a message via AIM to Quiknen
LuckyAce gave me this link:
I have to RANT---- You know it's really bad when -- - Page 4 - LX Forums | Dodge Charger Challenger Magnum | SRT8 | Chrysler 300 Forum
as i might have to do the same thing soon
Real Name: Ian Butler
(Click above picture to see modifications)
Click here to see My Garage
5.7L Hemi Registry #1537 Quiknen
Quiknen is offline
post #7 of 14 (permalink) Old 08-31-2010, 11:24 AM
Points: 1,623, Level: 1 Points: 1,623, Level: 1 Points: 1,623, Level: 1
SanDiegoMob's Avatar
Changing Inner tie rod ends this weekend thankfully dont need a new rack 100 bucks for a pair finally fix the severe play i have in my wheel.
2006 Chrysler 300c
Cool Vanilla
Ground Effects Body Kit
Bentley grill
F5 22's
Tint all the way around
SanDiegoMob is offline
post #8 of 14 (permalink) Old 09-07-2010, 10:52 PM
Points: 788, Level: 1 Points: 788, Level: 1 Points: 788, Level: 1
Car: 2006 chrysler 300c srt-8
i need to change mine also. I heard moog is pretty good brand with lifetime warranty.
koony is offline
post #9 of 14 (permalink) Old 10-15-2010, 08:52 AM Thread Starter
I did wind up putting a new Moog tie rod end on, but it wasn't the problem (although the old one did seem fairly worn). I am still getting the clunking, and when I have to brake from highway speed it shudders like CRAZY. Almost scary crazy. I have replaced the rotors and pads before you ask. What should I try now? Ball Joints? Inners? I wish I had read the message boards on these cars before I bought this car.
mrcooms is offline
post #10 of 14 (permalink) Old 10-15-2010, 06:17 PM
Tension struts.
After looking for best price I got mine from moparpartz.com for about $120 for the pair, delivered.
DESIREE is offline
tie rod ends and o-ring BigKent General Discussion on Issues / Trouble Shooting 16 12-31-2010 06:14 AM
Inner Tie Rod Ends 300C JAMES300 General Discussion 1 06-09-2010 08:59 AM
tie rod ends morgan82 General Discussion 2 06-05-2010 01:07 AM
No Tie Rod Ends MRettb2001 General Discussion 7 09-15-2009 09:16 PM
Tie Rod Ends? Where Can I Get Them? Rocker Chick General Discussion 7 06-16-2008 11:50 AM
