DIY: 2012 300 Pentastar 3.6L V6 Oil Change - Chrysler 300C Forum: 300C & SRT8 Forums
Tech Tips - DIY - How-To Member created and Member approved! From modifications to maintenance, find the step-by-step info you need here. (Only Moderators can post)
post #1 of 2 (permalink) Old 08-21-2012, 06:14 PM Thread Starter
Points: 860, Level: 1 Points: 860, Level: 1 Points: 860, Level: 1
Car: 2012 Chrysler 300
2012 3.6L Pentastar Oil Change
Jack here, i'm new to the forums and American cars. I've always been one to do my own maintenance on my car because no one's going to take care of it as well as you do. My 2012 300 just hit about 4,700 miles and it's time for it's first oil change! Haven't seen any DIY's on this yet so i'd thought i'd post this and hopefully it'll help those who are looking to change their own oil since this is very similar to how oil changes were done on my BMW 335i.
Requirements
-6 Quarts of 5w-30
**Pictured is Mobil1 Extended Performance 5w-30 which has excellent UOA's but I just discovered that it is NOT Chrysler MS-6395 spec'd. I will be switching to Amsoil Synthetic 5W-30 for the next oil change. Don't want to give the dealerships any reason to void your warranty :P
-Mopar MO-744 Oil Filter ($10.00 at the Dealer)
-8mm Socket
-13mm Socket
-15/16 inch Socket
-Ratchet(s) to accommodate the above listed sockets
-Oil Drain Pan
-Rags
-Means of lifting up your car
**In this DIY I used Rhino Ramps, if using a jack please refer to your manual for proper jack points
-About 20-30 minutes of your time
Underneath the car
Looking underneath there's a protective tray that needs to be removed in order to access the drain bolt. Fortunately there are only four 8mm (circled in red) bolts keeping the tray in place. Remove these then pull the tray outwards towards the rear. Slides right out!
Without the tray
Remove the 13mm bolt to drain the oil (Don't forget to unplug your oil fill cap up top for a faster drain)
Let all the oil drain out and then re-tighten the drain bolt. Leave the tray off and head up to the engine bay.
Engine Bay
Circled is the cap that holds the oil filter, remove it by using the 15/16" socket and turning counter clockwise. Once loose I prefer to hand loosen it.
Pull the old oil filter outwards to remove it. We are now going to install the new o-ring which should come with your oil filter. Pull it off and replace it with the new one.
O-Ring
Out with the old in with the new
After replacing the o-ring, place the new filter onto the cap with the prong side going into the oil cap. You should see the indentations for it and it should click into place. If installed right the filter will not fall out no matter how it's held. I usually like to apply a little bit of new oil to the filter but this is up to you. After replacing the filter and o-ring reinstall the oil filter cap.
Pour in 6 Quarts of new oil
Close the fill cap and clean up any oil with rags. Turn on your car and check for any leaks. Underneath and in the engine bay. Double check with your dipstick to make sure oil levels are correct as well. If everything checks out reinstall the tray underneath and you're done!! Congrats!!
FYI
It'd be a good idea to keep records and receipts for proof of maintenance in case the dealer decides to ask later on for warranty purposes. Have to have some kind of proof right? I just keep a log with receipts.
Feel free to comment if I may have missed something or if I could've clarified things any better. If anyone knows how to reset the oil change light please PM me or inform me so I can update this DIY. I haven't received the light yet but i'm sure it'll come on later. Also, I want to think that the 2011 is done the same way but I can never be too sure so if someone later verifies that it is or isn't I will be sure to update on that as well.
Sixth_vang is offline
The Following 3 Users Say Thank You to Sixth_vang For This Useful Post:
Gregg Von Urff (03-07-2013), leadfoot99 (04-22-2014), oceanstate88 (12-27-2013)
post #2 of 2 (permalink) Old 10-24-2012, 09:27 PM
Points: 4,483, Level: 1 Points: 4,483, Level: 1 Points: 4,483, Level: 1
Car: 2013 Chrysler 300C V6 AWD Luxury Series
Having front wheels on ramps, how much of old oil is left in the engine, given that car is tilted front to back and oil drain plug is in front?
753951 is offline
  LinkBacks (?)
LinkBack to this Thread: http://www.300cforums.com/forums/tech-tips-diy-how/100346-diy-2012-300-pentastar-3-6l-v6-oil-change.html
Posted By For Type Date
FIAT FREEMONT OPINIE FORUM Zobacz temat - Przegl?dy okresowe w silniku benzynowym This thread Refback 03-23-2016 02:31 PM
Zobacz temat - Przegl?dy okresowe w silniku benzynowym This thread Refback 02-24-2016 03:37 AM
Zobacz temat - Przegl?dy okresowe w silniku benzynowym This thread Refback 05-16-2015 09:28 AM
Zobacz temat - Przegl?dy okresowe w silniku benzynowym This thread Refback 09-04-2014 04:15 AM
Zobacz temat - Przegl?dy okresowe w silniku benzynowym This thread Refback 03-01-2014 08:18 PM
Zobacz temat - Przegl?dy okresowe w silniku benzynowym This thread Refback 07-26-2013 03:09 AM
FIAT FREEMONT OPINIE FORUM Zobacz temat - Przegl?dy okresowe w silniku benzynowym This thread Refback 07-25-2013 06:17 AM
FIAT FREEMONT OPINIE FORUM Zobacz temat - Przegl?dy okresowe w silniku benzynowym This thread Refback 06-25-2013 04:17 PM
Freemont Klub Polska :: Zobacz temat - Przegl?dy okresowe w silniku benzynowym This thread Refback 05-14-2013 05:18 AM
Freemont Klub Polska :: Zobacz temat - Przegl?dy okresowe w silniku benzynowym This thread Refback 03-05-2013 04:05 PM
Freemont Klub Polska :: Zobacz temat - Przegl?dy okresowe w silniku benzynowym This thread Refback 02-10-2013 08:03 AM
DIY: 2012 Pentastar 3.6L 300 Oil Change Sixth_vang 2nd Generation Chrysler 300 Discussion 11 11-15-2013 04:59 AM
CAI for 3.6L Pentastar blk300limited 2nd Generation Chrysler 300 Discussion 11 08-27-2012 08:32 PM
How hard is it to change suspension on 2012? wowpaulwow 2nd Generation Chrysler 300 Discussion 8 08-07-2012 10:09 PM
Pentastar Alert! stevesrt8 2nd Generation Chrysler 300 Discussion 8 05-02-2012 02:35 PM
Anyone gone from a Hemi to a Pentastar? Erik 2nd Generation Chrysler 300 Discussion 4 11-18-2011 07:25 PM
