How To Repair - faded lighting to Dual Zone Climate Control Panel - Page 4 - Chrysler 300C Forum: 300C & SRT8 Forums
» Auto Insurance
Tech Tips - DIY - How-To Member created and Member approved! From modifications to maintenance, find the step-by-step info you need here. (Only Moderators can post)
Old 11-08-2012, 05:56 PM   #31 (permalink)
Points: 6,971, Level: 1 Points: 6,971, Level: 1 Points: 6,971, Level: 1
therealfleen's Avatar
Member Number: 40424
What about this one? Do you think the blue would match better than white halos?
Sent from my iPhone using Autoguide.com App
05 300c
LMI Frankentake IV
Predator 93 Oct Tune
Billet Catch Can
Jet 180 T Stat
therealfleen is offline
The Following User Says Thank You to therealfleen For This Useful Post:
badgx (11-09-2012)
Old 11-09-2012, 07:27 AM   #32 (permalink)
Points: 27,386, Level: 1 Points: 27,386, Level: 1 Points: 27,386, Level: 1
badgx's Avatar
Member Number: 32952
Amazon.com: Amico 60mm Blue Car 18 SMD LED Angel Eye Halo Ring Light Bulb Headlight: Automotive
Excellent find
A ring with more LED's packed closer together is better, reduces cold spots i.e. gaps between LED's.
Blue would look odd with the green dash, go with the white LED's if you like but that's my opinion though
Don't forget to take measurements to determine the correct ring size. Measure a gazillion times if need be, it looks like 2 of them out of the 4 will be slightly smaller in size.
Will be interesting to see this build come together, I've not seen it done before, so will be a first here!
badgx is offline
Old 11-09-2012, 08:30 AM   #33 (permalink)
Originally Posted by badgx View Post
Excellent find
Thanks brother!
Old 11-09-2012, 09:30 AM   #34 (permalink)
Points: 5,099, Level: 1 Points: 5,099, Level: 1 Points: 5,099, Level: 1
Activity: 86% Activity: 86% Activity: 86%
Member Number: 28359
Jack, the panel leds will not work but I came up with an idea though
It might be possible to get small led halo rings and mount them to the inside top cover of the Dual Zone Climate Control Unit and the wires will solder to the relevant points. This all depends on halo ring sizes being available plus will need to do away with the plastic optical light distributor as it will no longer be required.
This is where the led halo ring will sit on the inside top cover and it can be held in place with glue. I might try this next time if I have another opportunity, perhaps using something like 6K diamond white led halo rings. See photo for illustration of possible mount place.
Looks a good idea to me.
As you know the advantage of LED' is that it should be a "Once only" replacement because LED's very rarely fail, whereas if you just replace with Bulbs again will require doing again in a few years.
Can you get Halo rings in Lots of different sizes then ?
Jack
jackwalton is offline
Old 12-09-2012, 08:53 AM   #35 (permalink)
Points: 82, Level: 1 Points: 82, Level: 1 Points: 82, Level: 1
Car: 2006 chrysler 300crd
Member Number: 41471
hi just done this to mine its a bit fiddly but is realy easy also did the the heated seat switches at the same time looks mint now there all working
lee181 is offline
Old 01-03-2013, 12:02 PM   #36 (permalink)
Points: 56, Level: 1 Points: 56, Level: 1 Points: 56, Level: 1
Car: 2008 Chrysler 300C srt design
Member Number: 41645
Hi
Thanks for the advice - I tried fixing the lights on my unit but for some reason the replacement bulbs would not light up (I only tried replacing two of them and I think I may have damaged part of the circuit board so I gave it up as a bad experience!
Your article is very good but I had trouble soldering (I'm not that experienced at it) and can't figure out why an adequate solder would not allow conductivity for the bulb to light up.
Jay
sinc1ok is offline
Old 01-03-2013, 12:14 PM   #37 (permalink)
Originally Posted by sinc1ok View Post
Hi
Jay
Jay, make sure the solder joints aren't touching. It won't work if the joints are touching.
Old 01-03-2013, 12:54 PM   #38 (permalink)
Thanks - I checked the joints and they aren't touching so I'm at a loss as to why this isn't working
sinc1ok is offline
Old 01-03-2013, 12:58 PM   #39 (permalink)
hmmm. Maybe Badgx could weigh in on this one...he's the guru....
Old 01-03-2013, 02:23 PM   #40 (permalink)
badgx's Avatar
OK dude, I have a question and its important. Did any part of your dual zone climate control illuminate before you attempted this repair or were they all already knock out ?
Test the bulb
De-solder and remove the replacement bulb from the circuit board for testing. When you removed the bulb get a 12 volt battery supply either AC or DC and connect across terminals to test to see if it illuminated. Polarity does not matter because the bulb is a filament type and will work in either direction. If the bulb illuminates then your bulb is OK.
Post back with an update..
Any chance you could post up a few photos of your circuit board and soldered joints?
badgx is offline
Climate control lighting flashman Lighting Discussion 3 07-29-2009 03:14 AM
