Go Back   Chrysler 300C & SRT8 Forum > Tech Tips Forum > Tech Tips - DIY - How-To
Old 02-16-2007, 09:39 AM   #1 (permalink)
FreebirdSRT's Avatar
Member Number: 4247
Trader Rating: (10)
How-To: LED Interior bulb list and install guide
I have seen a lot of interior LED light questions lately, on the various forums.
I am going to post the most updated list (with autolumination.com newest bulbs) of interior LED bulbs you will need for each LX vehicle. Since I now have one of each, I am getting swamped in my PM's. I don't mind answering each PM, but thought it would be easier if I posted all the bulbs you will need, for each LX, here. If I missed something or you have something to add to the LED list or the install guide. Let me know and I will edit it to the list, in this post. I hope this helps everyone out.
For the 300's, you will need the following bulbs
(2) 44mm rigid loop, 9 LED Festoon bulb (front map lights)
(1) 194 SMT tower LED (glove box)
(2) 44mm rigid loop, 9 LED Festoon bulb (courtesy lights, bottom of ea. front door)
(2) 194 SMT tower LED (rear seat map lights)
(1) 194 36 LED Array (trunk light)
(2) 194 4-star SMT (rear exterior license plate lights) for 300 C's and SRT's only.
(1) 194 4-star SMT (rear exterior license plate light) for the 300, Touring and Limited's.
For the Magnums, you will need the following bulbs.
(2) 44mm rigid loop, 9 LED Festoon bulb (rear hatch/lift gate)
There is no courtesy lights and glove box lights for the Dodge's. But you can order the glove box light and install in your glove box.
Then you will need a: (1) 194 SMT tower LED (glove box)
For the Chargers, you will need the following bulbs.
(1) 44mm rigid loop, 9 LED Festoon bulb (rear trunk light)
Installing the bulbs.
Front Map Lights.
1. From the click on/off end of the clear lens. Use a small jewelry/glasses flat head screw driver. Carefully wedge it into the on/off end of the lens and pry that end of the lens down. It may seem like it will snap, don't worry. The back end of the lens is held in place by 2 notches. Pull down with your fingers and it should pop free. Sometimes it pops free when you are wedged in with the flat head and pulling down.
2. Remove the rectangular metal reflector. I use a pair of pliers, because the metal may be hot. You will be left with the oem bulb and the rear refector, behind the bulb.
3. I use a small hand towel to reach up and remove the oem bulb, it will be very hot.
4. Take your pliers and get a grip on the rear reflector piece, closest to the roof. You will need to pull and twist to get the rear reflector to pop off of its 2 moutning points. At this point. You can throw away both metal reflectors, you will no longer need those.
5. Before installing the 44mm LED bulbs. Go to the socket prongs that hold the bulb in place. When you remove the oem bulb, the prongs tend to un-bend a bit. So take your fingers and lightly re-squeeze them a bit tighter. Then pop in your LED bulb and roll it until all the 9 led lights are aiming down. You can put your hand under the light to help see where it is aiming.
6. Take the clear lens and line it up with the 2 notches in back. Pop those into place. Then pop the click on/off end back up into place.
Courtesy Lights (bottom of ea. front Door: 300's only).
1. Pry the lens off and pull it down/out as best you can. It is tight, not alot of extra wire, in the door.
The loops on the end of the oem bulbs fit easliy on the folded socket prongs. Makes getting those bulbs off, easy. Just be careful the bulb is very hot.
The loops on the end of the LED bulbs are a lot tighter. Making it a little more difficult to get those installed.
2. Leave one of the folded socket prong ends folded. Work the loop end of the LED bulb, at an angle, down the folded end of the socket prong.
3. Un-fold the other socket prong end. But be very careful, the metal is very thin and you can break it if you un-fold and fold it a bunch of times or too quickly. Go slow, this is not a race.
4. You will need to work the loop end of the led bulb down that unfolded end as best you can. Once you think it is snug and tight. Carefully fold the socket prong end back down.
5. I test to make sure the bulb is connected well and making contact by lightly flicking the bulb with my finger. To simulate a door opening and closing and bumps in the road. Once the LED stays on after flicking it a few times. I re-intall the lens. You are done.
Rear seat map lights (similar to the front map lights)
1. From the click on/off end of the clear lens. Use a small jewelry/glasses flat head screw driver. Carefully wedge it into the on/off end of the lens and pry that end of the lens down. It may seem like it will snap, don't worry. The other end of the lens has a tab on it and simply pull the lens, after popping it from the on/off end and it will come out.
2. You should now see the oem 194 bulb and a rear reflector.
3. I use the small flat head to pop the 194 bulb out. I have a towel in the other hand to catch the hot 194 bilb.
4. Do not remove the rear reflector on the rear map lights.
5. Before installing the 194 tower SMT bulbs. Go to the socket prongs that hold the bulb in place. When you remove the oem 194 bulb, the prongs tend to un-bend a bit. So take your fingers and lightly re-squeeze them a bit tighter.
6. Once the new 194 LED is installed. Flick it a few times to make sure it stay on. If it doesn't. Pull the led bulb out and re-squeeze the socket prongs. Once the light stays on. Re-install the clear lens.
7. Take the end of the lens with the wedge on it and insert that into place. Then push in the on/off click end and you are done.
Trunks/Hatch door lights
1. 300
Remove the clear lens. Pop out the 921 bulb. It will be hot, use a small hand towel. Install the 194 end of the 36 LED Array. The Array will then hang down, by the wires. When you install the clear lens back on. Lay the LED Array on the lens (lights aiming towards the trunk floor) before popping it back on.
2. Magnum
Remove the large clear lens. Pop out both oem festoon bulbs, bulbs are hot. Gently re-squeeze the socket prongs together. Install the 44mm LED fetoon bulbs. Rotate them until the 9 LEDs of each festoon are aiming out the direction of the clear lens. Pop the clear lens back in.
3. Charger
Similar to the courtesy lights on the 300 doors. Remove the oem festoon bulb with a towel, bulb is hot. Slide one end of the LED festoon bulb down the folded socket prong. Gently unfold the other folded socket prong and work the other end of the LED festoon bulb down. Once it is snug in place and illuminated. Flick it a few times to make sure it is snug. Fold down the unfolded end of the socket prong.
Rear exterior license plate lights. (2) for the 300's (1) for the Magnum and Chargers.
1. Use a short handle phillips screw driver to remove the license plate housing screws.
2. Pull the entire lens down and out. Twist the 194 light socket loose, out of the back of the clear lens.
3. Pull out the 194 oem bulb. Insert the 194 4-star SMT bulb into the 194 socket. Push it in as far as it will go.
4. Go turn on your parking lights to test and make sure the license plate light illuminates. If it doesn't. You may have the 194 in backwards (reverse polarity). Pull the Bulb out rotate it in your hand. Then reinstall the 194. It should light up.
Eleanor Roosevelt, 1936
FreebirdSRT is offline
Old 02-18-2007, 06:30 AM   #2 (permalink)
Member Number: 4247
Trader Rating: (10)
Originally Posted by Buz-CCC View Post
Front map light does not have to be rigid loop just 44mm 9 LED festoon. Great write up should help many people doing this mod.
You are correct. You can buy/use the 44MM 9 LED Festoon bulb.
I order the rigid loops, since DCX puts a OEM rigid loop bulb in the front map lights. I use the same replacement.
Old 02-18-2007, 06:34 AM   #3 (permalink)
Member Number: 4247
Trader Rating: (10)
Originally Posted by 300on24s View Post
The front dome lights do not even have to be 44mm. Anywhere from 40-44mm works.
Great thread though!
True. Some members, almost 2 years ago, were even using the 39mm festoon bulbs. But found that even re-squeezing the socket prongs and inserting the smaller festoons. It did not make as snug/tight a fit than by going with the 44mm festoons.
If you also measure, from loop end to loop end, the oem map light bulbs. They are 1.75" = 44mm.
Old 03-02-2007, 02:33 PM   #4 (permalink)
Member Number: 4247
Trader Rating: (10)
Originally Posted by rjkusse View Post
Hey FreebirdSRT,
Can you take a picture of all of the changes after you are done? Not really sure I want to do this, so some pictures might help me make a decision.
They are pics from my Charger but the same lights you have in your 3CSRT.
Front seat map lights.
OEM halogen bulb on the L and the 44 mm LED on the R.
Both front seat map lights.
With the 44mm LEDs installed.
The rear map light with oem halogen bulb
The rear map light with the 194 LED bulb.
Old 03-02-2007, 02:38 PM   #5 (permalink)
Member Number: 4247
Trader Rating: (10)
So a 194 works in place of the 921 bulb? I can get 921 bulb in LED or a 194 in LED, which should I go with for the trunk light?
and does a 42mm festoon work for the door lights? it worked fine in my dome lights...
The 194 and 921 bulb both have the same size ends. So yes, a 194 LED bulb will fit in a 921 socket. The LED array/tray you want to get for the trunk is the 194 36LED array from Autolumination.com
You need to use the 44mm rigid loop LED festoon bulb for the courtesy light (on the bottom of each front door).
